Hi again, @david_2018. I recently revisited this thread and realized I'd failed to fully appreciate at the time your contribution.
The project did indeed need my attention again when the previous steering design caused one of the motors to fail. I spent a portion of the last two months watching Arduino tutorials, hoping again to pull this off. In reality, I learned just enough to realize that you'd written the code in two parts, but I didn't see how to put them together at the time. That was really very kind of you. I shouldn't even be the one doing this, let alone a stranger who no doubt has better things to do. So I really need to give a huge thank you for your time. If you're comfortable providing me with a mailing address via PM, I'd love to send you something nice for your efforts. Seriously.
When I uploaded the code I was amazed that it straight away did virtually everything I was hoping it would. You used commands in it that I've never even seen before (in my limited learning of this topic), so I don't know if I'd have ever put together a useful code. I will say it only seems to work in one direction (reverse, unless I swap the wires on the motor driver), so if you have any insight on why that might be, I'd love to hear it. Your code is below, along with a project description and a few small changes to more accurately reflect the joystick readings I pulled. Let me know if you don't want your username in the heading - I just wanted credit to go where credit was due.
Thanks again.
/* File: RC_V3
* Purpose: Control two motors mounted on opposite sides of a kart with a remote control transmitter.
* The user must be able to control the throttle and direction of each motor simultaneously,
* as well as independently for the purpose of steering.
* Version 2.0 : Updated software to work with new controller
* Developed by: david_2018 (as identified on arduino.cc)
#define MTR 5 //Motor right
#define MTL 6 //Motor left
#define DIR_R 7 //right direction
#define DIR_L 8 //left direction
#define FWD LOW
#define RVS HIGH
const byte steerPin = 10;
const byte throttlePin = 11;
const byte direcPin = 9;
const unsigned int pulseMin = 983; //minimum length of pulse
const unsigned int pulseMax = 1971; //maximum length of pulse
const unsigned int pulseMid = (983 + 1971) / 2; //centerpoint of pulse (1486);
const unsigned int deadband = 50; //dead band range for input pulses
unsigned int steer; //steering number
unsigned int throttle; //throttle number
unsigned int direc;
unsigned int pwmL; //pwm for left motor
unsigned int pwmR; //pwm for right motor
bool runMotors;
pinMode(steerPin, INPUT);
pinMode(throttlePin, INPUT);
pinMode(direcPin, INPUT);
pinMode(MTR, OUTPUT);
pinMode(MTL, OUTPUT);
pinMode(FWD, OUTPUT);
pinMode(RVS, OUTPUT);
steer = pulseIn(steerPin, HIGH, 250000);
throttle = pulseIn(throttlePin, HIGH, 250000);
direc = pulseIn (direcPin, HIGH, 250000);
Serial.print(F("pulse length steer: "));
Serial.print(steer);
Serial.print(F("\npulse length throttle: "));
Serial.print(throttle);
Serial.print(F("\npulse length direc: "));
Serial.print(direc);
Serial.print('\n');
//ensure pulse lengths are within allowed range
steer = constrain(steer, pulseMin, pulseMax);
throttle = constrain(throttle, pulseMin, pulseMax);
direc = constrain(direc, pulseMin, pulseMax);
steerFunct();
direcFunct();
speedFunct();
void steerFunct() {
unsigned int pwm = 0;
if (throttle >= (pulseMin + deadband)) {
pwm = map(throttle, (pulseMin + deadband), pulseMax, 0, 255);
pwmL = pwm;
pwmR = pwm;
//the actual steering code goes here
if (steer >= (pulseMid + deadband)) { //steer right - allow for deadband
unsigned int steerPercentage = map(steer, (pulseMid + deadband), pulseMax, 100, 0);
pwmR = pwmR * steerPercentage / 100u; // decrease right motor
//direct mapping to maximum pwm value
//pwmR = map(steer, (pulseMid + deadband), pulseMax, pwmR, 0)
//using 255 instead of 100 for greater precision
//unsigned int steerPercentage = map(steer, (pulseMid + deadband), pulseMax, 255, 0);
//pwmR = pwmR * steerPercentage / 255u;
else if (steer <= (pulseMid - deadband)) { //left turn - allow for deadband
unsigned int steerPercentage = map(steer, (pulseMid - deadband), pulseMin, 100, 0);
pwmL = pwmL * steerPercentage / 100u; // decrease left motor
void direcFunct() {
//forward
if (direc <= (pulseMid - deadband)) {
runMotors = true;
digitalWrite(DIR_R, FWD);
digitalWrite(DIR_L, FWD);
Serial.print(F("Direction: Forward\n\n"));
//Reverse
else if (direc >= (pulseMid + deadband)) {
runMotors = true;
digitalWrite(DIR_R, RVS);
digitalWrite(DIR_L, RVS);
Serial.print(F("Direction: Reverse\n\n"));
// dead zone
else {
runMotors = false;
Serial.print(F("Direction: Stop\n\n"));
void speedFunct() {
if (runMotors == true) {
// send pwm signal to motor
analogWrite(MTR, pwmR);
analogWrite(MTL, pwmL);
//stop motors
analogWrite(MTR, 0);
analogWrite(MTL, 0);
