Hello,
i have Arduino Uno and connected two MPU9250 units over SPI. For reading and general setup i use this library: GitHub - bolderflight/mpu9250: MPU-9250 sensor driver.
The problem is that mpus influences each other in measurements - if i rotate one unit 1 then the angles are changing as they should but in the same time im getting the same values from unit 2 and vice versa.
Using 10 and 9 pins for SS
How can i make these two units measure independently?
Wiring:
Code:
#include "MPU9250.h"
#include "SensorFusion.h"
MPU9250 imuu2(SPI, 10);
MPU9250 imuu(SPI, 9);
int status;
bool calibrateMag;
SF fusion;
void initSensor(MPU9250 &imu, int i) {
status = imu.begin();
if (status < 0) {
Serial.print("IMU initialization unsuccessful, num ");
Serial.print(i, DEC);
Serial.print("Status: ");
Serial.println(status);
while (1) {}
float hxb;
float hxs;
float hyb;
float hys;
float hzb;
float hzs;
if (calibrateMag) {
Serial.println("Starting calibrating mag!");
status = imu.calibrateMag();
if (status < 0) {
Serial.println("Failed to calibrate mag num " + i);
Serial.println("Mag calibration success, num " + i);
hxb = imu.getMagBiasX_uT();
Serial.print("hxb: ");
Serial.print(hxb);
hxs = imu.getMagScaleFactorX();
Serial.print("hxs: ");
Serial.print(hxs);
hyb = imu.getMagBiasY_uT();
Serial.print("hyb: ");
Serial.print(hyb);
hys = imu.getMagScaleFactorY();
Serial.print("hys: ");
Serial.print(hys);
hzb = imu.getMagBiasZ_uT();
Serial.print("hzb: ");
Serial.print(hzb);
hzs = imu.getMagScaleFactorZ();
Serial.print("hzs: ");
Serial.print(hzs);
imu.setMagCalX(hxb, hxs);
imu.setMagCalY(hyb, hys);
imu.setMagCalZ(hzb, hzs);
// serial to display data
while (!Serial) {}
calibrateMag = false;
initSensor(imuu, 0);
initSensor(imuu2, 1);
void readSensor(MPU9250 &imu, int i) {
float gx, gy, gz, ax, ay, az, mx, my, mz, temp;
float pitch, roll, yaw;
float deltat;
imu.readSensor();
ax = imu.getAccelX_mss();
ay = imu.getAccelY_mss();
az = imu.getAccelZ_mss();
gx = imu.getGyroX_rads();
gy = imu.getGyroY_rads();
gz = imu.getGyroZ_rads();
mx = imu.getMagX_uT();
my = imu.getMagY_uT();
mz = imu.getMagZ_uT();
deltat = fusion.deltatUpdate();
fusion.MadgwickUpdate(gx, gy, gz, ax, ay, az, mx, my, mz, deltat);
roll = fusion.getRoll();
pitch = fusion.getPitch();
yaw = fusion.getYaw();
// display the data
Serial.print(">"); //message starts
Serial.print(roll, 6);
Serial.print("\t");
Serial.print(pitch, 6);
Serial.print("\t");
Serial.print(yaw, 6);
Serial.print("\t");
Serial.print(i);
Serial.print("<"); //message ends
Serial.print("\r");
readSensor(imuu, 0);
delay(100);
readSensor(imuu2, 1);
delay(100);
Example output: each unit is facing diferent angle but they are returning same measurements… why?
Hope this better explain my problem.
roll pitch yaw MPU number
47.461639 77.757209 201.196044 0<
45.776214 77.349822 199.501327 1<
49.627929 78.219291 203.360366 0<
47.830818 77.824081 201.553924 1<
51.977386 78.666725 205.712493 0<
50.050743 78.286392 203.773483 1<
54.526542 79.089790 208.254882 0<
52.442893 78.742454 206.163772 1<
57.293212 79.500862 211.023101 0<
55.129859 79.179344 208.856918 1<
60.388511 79.892318 214.124450 0<
58.043712 79.594917 211.766143 1<
63.692874 80.253921 217.432495 0<
61.292774 79.992912 215.008209 1<
67.178504 80.646697 220.912292 0<
45.962116 72.089439 201.464065 1<
48.284492 72.210899 204.432205 0<
47.137386 71.819320 203.255386 1<
49.920509 72.669441 205.975021 0<
48.605247 72.269645 204.663726 1<
51.476627 73.115081 207.492996 0<
50.063709 72.716430 206.091522 1<
53.154975 73.526260 209.121124 0<
51.667743 73.147338 207.641571 1<
54.828243 73.915847 210.760681 0<
53.327766 73.558609 209.272308 1<
Thank you
