Two mySerial.begin(9600)'s causing issues
Alright, I'm dealing with this code at the moment and I have very close to working. I started with base code for a Conductivity sensor and then added bits of a pH sensor in. When I finished, It only printed pH so I backtracked and started un-commiting all of the pH parts and it started printing conductivity again. I've narrowed the problem down to a single line of code on line 21, mySerial0.begin(9600); If it's commited then the code prints pH, if it's not then it prints Conductivity. So can you not have two mySerial.begin(9600) ?
Here's the code I use:
#include <SoftwareSerial.h>
#define rx 3
#define tx 2
#define rx1 5
#define tx1 6
SoftwareSerial mySerial(rx, tx);
SoftwareSerial mySerial0(rx1, tx1);
String inputString = "";
String sensorStringOne = "";
String sensorStringTwo = "";
boolean inputStringComplete = false;
boolean sensorStringCompleteOne = false;
boolean sensorStringCompleteTwo = false;
float pH;
  mySerial.begin(9600);
  inputString.reserve(10);
  sensorStringOne.reserve(30);
  sensorStringTwo.reserve(30);
void serialEvent() {
  inputString = Serial.readStringUntil(13);
  inputStringComplete = true;
  if (inputStringComplete == true) {
    mySerial.print(inputString);
    mySerial.print('\r');
    mySerial0.print(inputString);
    mySerial0.print('\r');
    inputString = "";
  if (mySerial.available() > 0) {
    char inchar = (char)mySerial.read();
    sensorStringOne += inchar;
    if (inchar == '\r') {
      sensorStringCompleteOne = true;
  if (sensorStringCompleteOne == true) {
    if (isdigit(sensorStringOne[0]) == false) {
      Serial.println(sensorStringOne);
      print_EC_data();
  // pH code kinda starts here
  if (mySerial0.available() > 0) {
    char inchar0 = (char)mySerial0.read();
    sensorStringTwo += inchar0;
    if (inchar0 == '\r') {
      sensorStringCompleteTwo = true;
  if (sensorStringCompleteTwo == true) {
    Serial.print("pH: ");
    Serial.println(sensorStringTwo);
void print_EC_data(void) {
  char sensorstring_array[30];
  char *EC;
  char *TDS;
  char *SAL;
  char *GRAV;
  float f_ec;
  sensorStringOne.toCharArray(sensorstring_array, 30);
  EC = strtok(sensorstring_array, ",");
  TDS = strtok(NULL, ",");
  SAL = strtok(NULL, ",");
  GRAV = strtok(NULL, ",");
  Serial.print("EC:");
  Serial.println(EC);
  Serial.print("TDS:");
  Serial.println(TDS);
  Serial.print("SAL:");
  Serial.println(SAL);
  Serial.print("GRAV:");
  Serial.println(GRAV);
//f_ec= atof(EC);
Alright, I tried to use the AltSoftSerial library but that seemed to mess things up even more since then I didn't even get an output. I then learned that you can listen to two ports with software serial you just have to do a listen command. However, now my problem is that for some reason the mySerial0.listen(); doesn't seem to work despite it being just like the example code they provided. Here's my code again but slightly modified. It would be great if I could get a replacement that worked.
#define rx 11
#define tx 10
#define rx1 8
#define tx1 9
float pH;
  mySerial.listen();
    inputString = "";
      print_EC_data();
  mySerial0.listen();
  mySerial0.listen();
  mySerial.listen();
  char *EC;
  char *TDS;
  char *SAL;
  char *GRAV;
  float f_ec;
  Serial.println(EC);
//f_ec= atof(EC);
Well, I have connected the Atlas Scientific pH and Conductivity sensor but they both send data to me.
Hardware serial ports work much better than software serial. You get an extra one with the Arduino Leonardo or other 32u4 boards, or four with the Arduino Mega boards.
That's great! I'm using the Arduino Uno, does my board have two Hardware Serial ports I can use? If so I would love it if you could change my code to work with hardware serial. :slight_smile:
An Uno, or any Arduino based on an ATmega328 (Pro Mini, etc.), has only one hardware serial port.
