Hi! I using two Nema17 with Arduino uno and a A4988 driver. One of the motors used to turn just in one direction but accidentally I turned it with my hand and now it is just vibrating and doesn't turn anymore. I think the problem is I unset the power, but I don't know. Also, I don't understand what is wrong with my code, because there's only Motor X that's not turning and I tried to change it but it's still not working.
I would appreciate any help.
Thank you!
#include <CNCShield.h>
#define NO_OF_STEPS 200
#define SLEEP_BETWEEN_STEPS_MS 5
CNCShield cnc_shield;
StepperMotor *motorX = cnc_shield.get_motor(0);
StepperMotor *motorY = cnc_shield.get_motor(1);
cnc_shield.begin();
cnc_shield.enable();
Serial.println("==== Simultaneous motor control ====");
Serial.println(" For each motor, indicate: number of steps, direction (clockwise or counterclockwise), and speed (steps/sec).");
// Collecting information for motor X
Serial.println("\n=== Motor X ===");
int nbPasX = getSteps();
int directionX = getDirection();
int vitesseX = getSpeed();
motorX->set_speed(vitesseX);
motorX->set_dir(directionX);
// Collecting information for motor Y
Serial.println("\n=== Motor Y ===");
int nbPasY = getSteps();
int directionY = getDirection();
int vitesseY = getSpeed();
motorY->set_speed(vitesseY);
motorY->set_dir(directionY);
// Calculating the delay between steps for each motor
int delayTimeX = 1000 / vitesseX; // Delay for motor X
int delayTimeY = 1000 / vitesseY; // Delay for motor Y
// Executing movements in parallel
Serial.println("\nMotors moving simultaneously...");
for (int i = 0; i < max(nbPasX, nbPasY); i++) {
if (i < nbPasX) motorX->step();
if (i < nbPasY) motorY->step();
delay(min(delayTimeX, delayTimeY));
Serial.println("\nMovements completed.");
delay(2000); // Wait before restarting
// Function to get the number of steps
int getSteps() {
Serial.print("Number of steps: ");
while (Serial.available() == 0) {}
String pasStr = Serial.readStringUntil('\n');
return pasStr.toInt();
// Function to get the direction (H = clockwise, A = counterclockwise)
int getDirection() {
Serial.print("Direction: (H = clockwise, A = counterclockwise) : ");
String dirStr = Serial.readStringUntil('\n');
dirStr.trim();
return (dirStr == "A" || dirStr == "a") ? COUNTER : CLOCKWISE;
// Function to get the speed in steps per second
int getSpeed() {
Serial.print("Speed (steps/second): ");
String speedStr = Serial.readStringUntil('\n');
return speedStr.toInt();
