Hello!
Im totally newbie about arduino, but I have a past with different (microchip, st) controllers.
I would like to build a proof of concept audio application, where I need at least two analogue stereo audio outputs and possibly a MIDI output.
Are there any shields for this application, or shall I thinking about building something?
Thanks for your answers!
Forget it, you can't do that on an Arduino Uno.
That's probably needs I2S DACs and an Arduino that can drive I2S.
Grumpy_Mike:
I have two analogue stereo audio outputs (two DFmini players = two stereo signals)
I use two libraries.
#include <DFRobotDFPlayerMini.h>
#include <DFPlayer_Mini_Mp3.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial1 (8, 9);
SoftwareSerial mySerial2 (10, 11);
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
Serial.begin (9600);
mySerial1.begin(9600);
delay (100);
mp3_set_serial (mySerial1);
delay (100);
mp3_set_volume (14); // Set volume value. From 0 to 30 (First Analog signal)
mySerial2.begin(9600);
if (!myDFPlayer.begin(mySerial2)) {
while(true);
myDFPlayer.volume(18); //Set volume value. From 0 to 30 (Next analog signal)
mp3_play (1); //Play first song from MP3 player from serial port rx tx 8 9
myDFPlayer.play(4); //Play song Nr4 from MP3 player from serial port rx tx 10 11
(My English very bad)
jpapp:
Where is the data coming from for all these outputs? What processing is needed?
It doesn't sound like an Arduino project but then the specification is rather short of detail.
Steve
This thread started in the middle of last year.
That is NOT doing it with an Arduino that is doing it with two external sound players. The fact that the Arduino is controlling them is irrelevant. If you want to just trigger two sounds then some sound players will allow up to 14 sounds to be triggered at once. But this WAS NOT what the OP was asking about.
This sounds like a job for a full-blown DSP chip, although "application" could be anything, but the presence of MIDI out suggests something heavyweight.
You don't need a powerful DSP, but proper I2S hardware matters.
I've supported 4 channel output on Teensy 3.2 (ARM Cortex-M4 at 96 MHz) for years, and also 8 channel output using CS42448 since mid-2017.
Info here:
https://oshpark.com/shared_projects/2Yj6rFaW
Old 8 bit AVR is definitely under-powered and lacks I2S. But even mid-range microcontrollers with proper I2S digital audio ports can do this with good software.
