Hello, I need help I have this message error it saids¨ two or more data types in declaration of timeout¨ can someone help me this is my code just to let you know Thanks.
I will put an asterisk where the error is.
// Include Libraries
#include "Arduino.h"
// Pin Definitions
// Global variables and defines
// There are several different versions of the LCD I2C adapter, each might have a different address.
// Try the given addresses by Un/commenting the following rows until LCD works follow the serial monitor prints.
// To find your LCD address go to: Arduino Playground - I2cScanner and run example.
#define LCD_ADDRESS 0x3F
//#define LCD_ADDRESS 0x27
// Define LCD characteristics
#define LCD_ROWS 2
#define LCD_COLUMNS 16
#define SCROLL_DELAY 150
#define BACKLIGHT 255
// object initialization)
LiquidCrystal_I2C
// define vars for testing menu
const int timeout = 10000;
char menuOption = 0;
long time0;
// Setup the essentials for your circuit to work. It runs first every time your circuit is powered with electricity.
// Setup Serial which is useful for debugging
// Use the Serial Monitor to view printed messages
while (!Serial) ; // wait for serial port to connect. Needed for native USB
Serial.println("start");
// initialize the lcd
lcdI2C.begin(LCD_COLUMNS, LCD_ROWS, LCD_ADDRESS, BACKLIGHT);
menuOption = menu();
// Main logic of your circuit. It defines the interaction between the components you selected. After setup, it runs over and over again, in an eternal loop.
if(menuOption == '1') {
// LCD 16x2 I2C - Test Code
// The LCD Screen will display the text of your choice.
lcdI2C.clear(); // Clear LCD screen.
lcdI2C.print(" Circuito.io "); // Print print String to LCD on first line
lcdI2C.selectLine(2); // Set cursor at the begining of line 2
lcdI2C.print(" Rocks! "); // Print print String to LCD on second line
if (millis() - time0 > timeout)
// Menu function for selecting the components to be tested
// Follow serial monitor for instrcutions
char menu()
Serial.println(F("\nWhich component would you like to test?"));
Serial.println(F("(1) LCD 16x2 I2C"));
Serial.println(F("(menu) send anything else or press on board reset button\n"));
while (!Serial.available());
// Read data from serial monitor if received
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if(c == '1')
Serial.println(F("Now Testing LCD 16x2 I2C"));
Serial.println(F("illegal input!"));
return 0;
time0 = millis();
return c;
