Two programs in one
Hi everyone,
i wanted to make a program that is able to:
  1. Open a relay after a certain amount of time once a specific input was triggered
  2. Open another relay instantly after a specific button on an IR remote was pressed
So i made my research and found both of these programs, however, there is a problem that i dont know how to put them into a one loop, would that be difficult? How can it be done?
Here is the program of delay:
int LED = 11;
int BUTTON = 13;
unsigned long previousMillis = 0;
const long interval = 2000;
void setup(){
pinMode(LED,OUTPUT);
pinMode(BUTTON,INPUT);
void loop(){
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
if(digitalRead(BUTTON) == HIGH){
digitalWrite(LED,LOW);
}else{
digitalWrite(LED,HIGH);
and here is the code of another program:
#include <IRremote.h>
int RECV_PIN = 12;
int mRelay = 13;
IRrecv irrecv(RECV_PIN);
decode_results results;
pinMode(mRelay, OUTPUT);
pinMode(4, OUTPUT);
irrecv.enableIRIn(); // Start the receiver
int on = 0;
unsigned long last = millis();
if (irrecv.decode(&results)) {
if (results.value == 0xD || results.value == 0x80D) { // TIVO button
// If it’s been at least 1/4 second since the last
// IR received, toggle the relay
if (millis() - last > 250) {
on = !on;
digitalWrite(mRelay, on ? HIGH : LOW);
last = millis();
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
Rather than posting two programs (badly), why not post the one program you tried to write that does both things?
Oh, sorry, ill post it down below, What i tried to do was make my delay program as a function anode() and launch it at the end of the main loop:
int RECV_PIN = 12;
int muteRelay = 13;
int anodeRelay = 6;
int BUTTON = 5;
pinMode(muteRelay, OUTPUT);
pinMode(4, OUTPUT);
pinMode(anodeRelay,OUTPUT);
anode ();
int on = 0;
// if (millis() - last > 250) {
on = !on;
digitalWrite(muteRelay, on ? HIGH : LOW);
// last = millis();
void anode();
void anode() {
digitalWrite(anodeRelay,LOW);
}else{
digitalWrite(anodeRelay,HIGH);
What was the result? Does it work?
   void anode();
When you call the function digitalWrite, do you write
void digitalWrite(pin, state);
or just
You've confused calling a function with defining a function. You only need the void when you define a function. I would suggest doing at least the first little part of any of the many C++ tutorials online to get the basics of stuff like that. This can be a very frustrating endeavor if you don't know these sorts of things.
