I have two pushbuttons that make a stepper motor spin in two different cycles, and I have attempted to incorporate interrupts so that you don’t need to time the button press according to the stepper motor cycle.
Ultimately, the code works pretty well, except for how I seem to be one “step” (badumtss) away from getting the interrupts to work properly, since i have to define them in the setup and disable them first thing in the loop, in an attempt to accomplish the following:
- Power up prototype
- Motor is stationary
- Choose either button to BEGIN corresponding cycle
- Be able to use interrupts to switch to other cycle while in still the “starting” cycle
- Profit
My refined code is included, can you point out what I’m missing? Thanks.
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Connect a stepper motor with 200 steps per revolution (1.8 degree)
// to motor port #2 (M3 and M4)
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
int button2 = 0;
int button3 = 0;// the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
// Variables will change:
volatile int start=0;
AFMS.begin();
pinMode(2,INPUT);
pinMode(3,INPUT);
attachInterrupt(0, stroke, CHANGE);
attachInterrupt(1, scrub, CHANGE);
detachInterrupt(0);
detachInterrupt(1);
button2 = digitalRead(2);
button3 = digitalRead(3);
if (button2 == HIGH)
start=1;
else if (button3 == HIGH)
start=2;
switch (start){
case 1: //stroking speed
myMotor->setSpeed(60);
myMotor->step(80, FORWARD, DOUBLE);
myMotor->step(60, BACKWARD, DOUBLE);
case 2: //scrubbing speed
myMotor->setSpeed(100);
myMotor->step(20, FORWARD, INTERLEAVE);
myMotor->step(10, BACKWARD, INTERLEAVE);
myMotor->step(30, FORWARD, INTERLEAVE);
myMotor->step(20, BACKWARD, INTERLEAVE);
void stroke()
myMotor->
void scrub()
