Two PWM using two different Timers
Hello my friends
I know there are many links about PWM studies BUT I watched so many of them and I could not solve this little code yet.
I try to turn on two leds with an arduino MEGA using any pin to generate two different PWM with different frequency ( one led 50 Hz and the other led 10 Hz ) I think it has to be designed with two different TIMERS because I need two different frequencies. Also is very important for these code do not include any DELAYS.
I tried using libraries like timerone and timerthree but I didnt get good results
Thanks for your help.
Do you require a square wave or differing duty cycles?
I'm missing the code you used in your post. Which pins are the LEDs connected to? Why do you need different frequencies for the LEDs?
thanks guys for reply
Todd: Yes, I need to change the duty cycle
Pylon: Any pin for both, I need two frequencies because I need to control two PID, and I need these frequencies for a good functioning of them
Really I appreciate your help
You can try this. I've written it at work and don't have a Mega with me to try it so it may be completely wrong. It does compile.
It's supposed to use timers 1 and 3 to give you a 50Hz PWM on pin 11 and a 10Hz PWM on pin 5. The duty cycle should cycle on each, changing every 200uS going from ~0% to ~100% and back etc.
At least that's the intent. I can debug this evening if this doesn't work as expected.
#define TOP_T1      0x4E20      //ticks     Period E = N x 2 / Fclkt = 0x4e20 x 2 / 2MHz = 20mS
#define TOP_T3      0x30D4      //ticks     Period E = N x 2 / Fclkt = 0x30d4 x 2 / 250kHz = 100mS
#define BOTTOM      0x0000      //ticks     lowest count value
#define DC_TICK_TIME    200ul    //uS        time between duty cycle ticks
const byte pinOC1A = 11;
const byte pinOC3A = 5;
bool
    bDir1,
    bDir3;
    pinMode( pinOC1A, OUTPUT );
    digitalWrite( pinOC1A, LOW );
    pinMode( pinOC3A, OUTPUT );
    digitalWrite( pinOC3A, LOW );
    //waveform gen mode 8 (PWM, phase & frequency correct); WGM3:0 = 1000
    //prescaler = clkio/8 (010)
    //TOP == ICR1 = 20000d; count up/down (== 20mS or 50Hz
    //OCR1A varies from 0 to 40000 (TOP)
    TCCR1A = (1<<COM1A1);
    TCCR1B = (1<<WGM13) | (1<<CS11);
    ICR1 = TOP_T1;
    OCR1A = TOP_T1 >> 1;    //should give 50% duty cycle
    bDir1 = true;
    //prescaler = clkio/64 (011)
    //TOP == ICR1 = 25000d; at 250kHz clk == 100mS or 10Hz
    //OCR1A varies from 0 to 25000 (TOP)
    TCCR3A = (1<<COM3A1);
    TCCR3B = (1<<WGM13) | (1<<CS31) | (1<<CS30);
    ICR3 = TOP_T3;
    OCR3A = TOP_T3 >> 1;    //should give 50% duty cycle
    bDir3 = false;
}//setup
    static unsigned long
        timeTick=0;
    unsigned long
        timeNow;
    timeNow = micros();
    if( timeNow - timeTick >= DC_TICK_TIME )
        timeTick = timeNow;
        //vary the duty on pin 11
        if( bDir1 )
            if( OCR1A < TOP_T1 )
                OCR1A = OCR1A + 1;
                bDir1 = false;
        }//if
            if( OCR1A > BOTTOM )
                OCR1A = OCR1A - 1;
                bDir1 = true;
        }//else
        //vary the duty on pin 5
        if( bDir3 )
            if( OCR3A < TOP_T3 )
                OCR3A = OCR3A + 1;
                bDir3 = false;
        }//if
            if( OCR3A > BOTTOM )
                OCR3A = OCR3A - 1;
                bDir3 = true;
        }//else
    }//if
}//loop
Blackfin thank you
Ill check this code and Ill tell you later.
As the frequencies (10/50 Hz) are so low, you easily could do it with a millis() timer and software PWM - leaving the hardware untouched for other tricks.
Lastchancename: Yes I ll think about that, Thank you !
