Two rotary encoders work fine, three don't
Hi everyone,
I’m aiming to work with eventually nine rotary encoders (KY-040). I started with one. The code worked well, for a second encoder I copied the relevant snippet and adjusted the variables. Works perfectly fine. (With this little code I can still go without interrupts.)
So I was thinking that I can just do the same for the third encoder (like: defining variables for the third encoder and copying the part needed). What I have now is: I am still able to read encoder 1 and 2. For encoder 3 nothing happens. What exactly am I missing? Thanks for sparing your time!
three-encoders.ino (2.42 KB)
Hello there!
Can you post a schematic or picture of your setup, showing where are the connections are?
Your pinB inputs are floating - all the pins need to be INPUT_PULLUP.
Write one function to handle any of the encoders and pass the pin numbers to it - otherwise
you have 3 nearly identical copies of the code for 3 times as many bugs to lurk in!
Or even use arrays for the pin numbers and counts.
bos1714:
Hello there!
A schematic is attached. (The picture doesn’t show the KY-040 encoders, but please imagine them as such.)
MarkT:
I see! I was wondering whether I needed to define the pin modes of the B pins.
MarkT:
Ok, a function to handle any of the encoders. I will work on it!
(Yeah, three almost identical copies is not an elegant manner.)
ickeai:
A schematic is attached. (The picture doesn't show the KY-040 encoders, but please imagine them as such.)
Why would they be different to the A pins?
The most advanced part is using pass by reference for the count variables - might be easier to pass
an integer index and use arrays for all the pin numbers and count variables.
Ok, I managed it! (And I realised the problem wasn’t exactly my sketch but apparently current supply of the third encoder on the breadboard, so plugged all of them directly to the arduino.)
I attached my ‘beautified’ sketch for those who are interested.
read-rotary-encoders.ino (1.4 KB)
