Two seperate, independent LEDblink?
Hi.
I'm trying to get output 1 and output 2 to go low and high independently.
What I'm trying to do;
Output 1 should control a light (through a relay module) that turns on for 14 hours and off for 10.
Output 2 should control a pump (through a relay module) thats supposed to be off for several days then on for 20 seconds or so, then repeat.
I've read a lot of examples but all seems quite advanced. Is it an easy way to do this?
I read about the scheduler library, but I don't have a Due, Zero or MKR1000, just got an Uno r3.
I also read this article; https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
But can't seem to figure out how to "transfer" this to my project.
consider the following
#define Period1     50
#define Period2    100
#define Period3    150
int           ang   = 0;
int           dAng  = 1;
int           st1   = 0;
int           dist  = 0;
unsigned long msec1 = 0;
unsigned long msec2 = 0;
unsigned long msec3 = 0;
void loop () {
    unsigned long msec = millis();
    // period 1 actions
    if (msec - msec1 > Period1) {
        msec1 = msec;
        ang += dAng;
        myservo.write (ang);
        if (0 < dAng && 180 <= ang)
            dAng = -dAng;
        else if (0 > dAng && 0 >= ang)
            dAng = -dAng;
    // period 2 actions
    if (msec - msec2 > Period2) {
        msec2 = msec;
        // state1 action
        if (st1)
            digitalWrite (LED, HIGH);
        else                // state2 action
            digitalWrite (LED, LOW);
        st1 = ! st1;      // toggle state
    if (msec - msec3 > Period3) {
        msec3 = msec;
        // period 3 actions
        Serial.print   ("Distance: ");
        Serial.println (dist);
    // do something that doesn't need to wait
    lcd.setCursor(0, 1);
    lcd.print(millis() / 1000);
This will allow you to control 4 outputs each with separate on and off periods
const byte ledPins[] = {3,5,6,9};
const byte NUMBER_OF_LEDS = sizeof(ledPins);
unsigned long startTimes[NUMBER_OF_LEDS] = {};
byte indexes[NUMBER_OF_LEDS] = {0};
const byte MAX_NUMBER_OF_PERIODS = 10;
unsigned long periods[][MAX_NUMBER_OF_PERIODS] =    //periods for each LED.  zero indicates end of sequence
  {1000, 2000, 1500, 2500, 0},
  {500, 200, 1000, 2000, 3000, 4000, 0},
  {400, 1000, 1500, 2000, 0},
  {1100, 2200, 0}
  for (int led = 0; led < NUMBER_OF_LEDS; led++)
    pinMode(ledPins[led], OUTPUT);
  unsigned long currentTime = millis();
  for (int led = 0; led < NUMBER_OF_LEDS; led++)  //iterate through the LEDs
    if (currentTime - startTimes[led] >= periods[led][indexes[led]])  //? time to change ?
      digitalWrite(ledPins[led], !digitalRead(ledPins[led]));  //flip led state
      startTimes[led] = currentTime;  //save start time of state
      indexes[led]++;                    //increment index
    if (periods[led][indexes[led]] == 0)  //if next period is zero (end of sequence)
      indexes[led] = 0;        //reset period index for this LED
  }  //end for loop
It is easily adjusted to use only 2 outputs and longer periods
See this example: Blink multiple LED without delay
