I would like to use the potentiometer to control two servos moving opposite direction at the same speed. The reason is, I want to connect two servos to the same robot arm and thus would have to move opposite directions
is this possible to do on an arduino board??
i have seen how to use one servo on the servo knob example but cant figure out how to make it work for what i am trying to do
I have never used a servo (yet), but of course this is possible. The Arduino and your sketch sits in-between the pot and the servo... It's up to your sketch to control the servo... You could run the servo totally under software control with no pot at all!
Simple test code for making reverse operating servos.
//zoomkat 10-09-14 serial servo test
//type servo position 0 to 180 in serial monitor
//opposite side servos rotate together
String readString;
#include <Servo.h>
Servo myservo1; // create servo object to control a servo
Servo myservo2;
myservo1.attach(8);
myservo2.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
myservo1.write(n);
myservo2.write(180-n); //turns opposide servo in desired direction
readString="";
