Two servos whith two buttons.
Hello,
i found this Code but wen i fill it whith the Servo 2 and Switch2 Code an error is coming called:
'checkSwitches' was not declared in this scope
I want to control switch 1 for servo 1 and switch 2 for servo 2.
Any Ideas?
Thanks for help
Sven from Germany
#include <Servo.h>
// create servo object to control a servo
// twelve servo objects can be created on most boards
Servo myservo1;
Servo myservo2;
const byte switch1      = 2;    //switch press = LOW
const byte switch2      = 3;    //switch press = LOW
const byte heartBeatLED = 13;
byte cycleServo1Flag    = 0;    //= 0 stopped, = 1 going to 180, = 2 going to 0
byte cycleServo2Flag    = 0;    //= 0 stopped, = 1 going to 180, = 2 going to 0
byte lastSwitch1;               //current switch state
byte lastSwitch2;               //current switch state
byte servoDelay         = 15;   //15ms
int servo1Pos;
int servo2Pos;
//timing variables
unsigned long MillisHeartBeat;
unsigned long testSwitchMillis;
unsigned long servoMillis;
  myservo1.attach(8);
  myservo1.write(servo1Pos);
  myservo2.attach(9);
  myservo2.write(servo2Pos);
  pinMode(heartBeatLED, OUTPUT);
  pinMode(switch1, INPUT_PULLUP);         //push = LOW
  lastSwitch1 = digitalRead(switch1);
  pinMode(switch2, INPUT_PULLUP);         //push = LOW
  lastSwitch2 = digitalRead(switch2);
} //END of setup()
  //code to see if the sketch is blocking, LED will toggle every 500ms
  if (millis() - MillisHeartBeat >= 500)
    MillisHeartBeat = millis();
    //toggle LED state
    digitalWrite(heartBeatLED, !digitalRead(heartBeatLED));
  //time to check the switches?
  if (millis() - testSwitchMillis >= 50)
    testSwitchMillis = millis();
    checkSwitches();
  //run at loop speed
  checkServos();
  //none blocking code here
}  //END of loop()
//                                c h e c k S e r v o s ( )
void checkServos()
  //servo #1
  //cycleServo1Flag = 0 stopped, = 1 going to 180, = 2 going to 0
  //if enabled, has servoDelay ms gone by?
  if (cycleServo1Flag == 1 && millis() - servoMillis >= servoDelay)
    //reset timer
    servoMillis = millis();
    servo1Pos++;
    //only go to 180
    if (servo1Pos > 180)
      //at 180 now get ready to go lower
      servo1Pos = 179;
      //change to other direction
      cycleServo1Flag = 2;
    } //finished going to 180
  } //if
  else if (cycleServo1Flag == 2 && millis() - servoMillis >= servoDelay)
    //reset timer
    servo1Pos--;
    if (servo1Pos < 0)
      //stop servo movement
    } //finished going to 0
  } //else if
  //servo #2
  //cycleServo2Flag = 0 stopped, = 1 going to 180, = 2 going to 0
  //add your second servo code here
} //END of checkServos()
//                              c h e c k S w i t c h e s ( )
void checkSwitches()
  //switch #1
  byte currentState = digitalRead(switch1);
  //has this switch position changed?
  if (lastSwitch1 != currentState)
    //update to the new state
    lastSwitch1 = currentState;
    //was the switch just pushed?
    if (lastSwitch1 == LOW)
      //allow servo 1 movment
      cycleServo1Flag = 1;
      //start at 0 degrees
      servo1Pos = 0;
  } //if
  //switch #2
  currentState = digitalRead(switch2);
  if (lastSwitch2 != currentState)
    lastSwitch2 = currentState;
    //add your second switch code here
  } //if
} //END checkSwitches()
It compiles fine for me for an Uno, IDE 1.6.12.
Yes the Sketch works but i have a Problem to Add Servo 2 and Switch 2 into the Sketch
this one here controll 1 servo with 1 button
Post the version that fails, so we can see what you've done wrong!
