Two speakers with different outputs
I am making a project where I have 3 ultrasonic sensors (left, center, and right). when the left sensor detects, it will make the first speaker beep, then if the right sensor detects, it will make the second speaker beep. and when the center sensor detects, both speakers beep. is there a way to make this? any suggestions would be nice also, thank you
Why not?
It is pretty obviuous.
Do you plan to use a separate amplifier?
Or a piezo buzzer?
Depends on how you make the sound.
An active buzzer has an internal oscillator that produces sound when powered, so it only needs a DC voltage to operate. you don't choose the frequency.
A passive buzzer like a piezo, on the other hand, requires an external signal, typically a square wave, to produce sound, as it doesn't have an internal oscillator.
The active buzzer is easier to use, while the passive one offers more control over the frequency of the sound it produces.
The tone() function in Arduino works well for a passive buzzer. You get to pick the frequency and duration of the tone. The drawback is that it can only drive one pin so you would not be able to use tone() for two piezos at the same time.
➜ This could easily work if you get two active buzzers rather than simple piezos and you don't mind about the frequency. You just activate the buzzer pin (or the pin controlling the power of the active buzzer) when you want to get a sound. It's as simple as turning a led on or off.
if you want to control the frequency, then there are waveform generator chips ( like the AD9833, a low power, programmable waveform generator capable of producing sine, triangular, and square wave outputs) that you could use or you would have to code your own wave generation. Depending on the arduino you use and frequency you want, this is going to be "some work" (If you want the same frequency out of the two pins it might be easy to modify the underlying tone() code to toggle one or two pins instead of just one)
Can you post an annotated schematic showing what you are planning on building?
