two stepper running to same time
Hi there,
Im trying to get two stepper motors to rotate at the same time. when i run the program (shown below) both steppers rotate but NOT AT THE SAME TIME:(. the first one rotates and then the second one rotates. is there a way to mod this program so BOTH STEPPERS RUN AT THE SAME TIME:). ANY HELP would be appreciated. thanks in advance. this is the code that im using (its basically from the samples, just modifies a bit):
CHEERS!!
#include <AccelStepper.h>
#include <MultiStepper.h>
AccelStepper stepper(1, 4, 9);
AccelStepper stepper2(1, 3, 8);
stepper.setMaxSpeed(2000.0);
stepper.setAcceleration(500.0);
stepper2.setMaxSpeed(2000.0);
stepper2.setAcceleration(500.0);
float val = 0 ;
float val2 = 0 ;
void loop(){
if (Serial.available() > 0 ) {
val = Serial.parseFloat( );
Serial.print("stepper 1 = ");
Serial.println(val);
stepper.runToNewPosition(val);
val2 = Serial.parseFloat( );
Serial.print("stepper 2 = ");
Serial.println(val2);
stepper2.runToNewPosition(val2);
stepper.runToNewPosition() is a blocking function. Use stepper.run() for both motors.
Also I think you will need to get both distance values before you start either motor moving. You may find some useful ideas in Serial Input Basics - simple reliable ways to receive data.
...R
float val = 0 ;
float val2 = 0 ;
void loop(){
Have you ever heard of a stepper that is able to step 3.14159 steps? I haven't, either.
Thank you so much for all your help and feedback, I'm so close to finishing my proto this is all I'm missing.
https://forum.arduino.cc/index.php?topic=93706.0
