Two TF02 pro LiDar sensor with arduino mega. i want to make blind corner saftey system using horn and redlight activating by relays this code doesnt
#include <SoftwareSerial.h>
#define RELAY1_PIN 4
#define RELAY2_PIN 3
#define TF02_1_RX_PIN 19   // Pin for TF02 sensor 1 RX (Green) - Serial1 RX1
#define TF02_1_TX_PIN 18   // Pin for TF02 sensor 1 TX (White) - Serial1 TX1
#define TF02_2_RX_PIN 17   // Pin for TF02 sensor 2 RX (Green) - Serial2 RX2
#define TF02_2_TX_PIN 16   // Pin for TF02 sensor 2 TX (White) - Serial2 TX2
const int NUM_SAMPLES = 5;   // Number of samples for averaging
const int MIN_DISTANCE_CHANGE = 5;   // Minimum change in distance (in cm) to count as significant
uint16_t dist_cm1, dist_cm2;          // LiDAR actually measured distance values in centimeters
uint16_t distBuffer1[NUM_SAMPLES];    // Buffer to store the last readings for sensor 1
uint16_t distBuffer2[NUM_SAMPLES];    // Buffer to store the last readings for sensor 2
uint8_t bufferIndex1 = 0, bufferIndex2 = 0; // Index to keep track of buffer position
const uint8_t HEADER = 0x59;          // Data package frame header
  Serial.begin(115200);              // Set the Baud rate of Arduino and computer serial port
  Serial1.begin(115200);             // Set the Baud rate of LiDAR 1 and Arduino Serial1 port
  Serial2.begin(115200);             // Set the Baud rate of LiDAR 2 and Arduino Serial2 port
  pinMode(RELAY1_PIN, OUTPUT);
  pinMode(RELAY2_PIN, OUTPUT);       // Initialize relay pins as output
  digitalWrite(RELAY1_PIN, HIGH);    // Ensure relays are off at start
  digitalWrite(RELAY2_PIN, HIGH);    // Ensure relays are off at start
  // Initialize distance buffers with large initial values
  for (int i = 0; i < NUM_SAMPLES; i++) {
    distBuffer1[i] = 10000;
    distBuffer2[i] = 10000;
  Serial.println("Setup complete");
  bool vehicleApproaching1 = checkSensor(Serial1, distBuffer1, bufferIndex1, "Sensor 1");
  bool vehicleApproaching2 = checkSensor(Serial2, distBuffer2, bufferIndex2, "Sensor 2");
  if (vehicleApproaching1 || vehicleApproaching2) {
    // Activate both relays (LOW)
    digitalWrite(RELAY1_PIN, LOW);
    digitalWrite(RELAY2_PIN, LOW);
    Serial.println("Relays activated");
    // Deactivate both relays (HIGH)
    Serial.println("Relays deactivated");
  delay(100);
bool checkSensor(HardwareSerial &serial, uint16_t distBuffer[], uint8_t &bufferIndex, const char* sensorName) {
  if (serial.available() >= 9) { // Check if the serial port has available data
    if (serial.read() == HEADER && serial.read() == HEADER) { // Determine data package frame header 0x59
      byte highByte = serial.read();
      byte lowByte = serial.read();
      uint16_t currentDist = ((uint16_t)highByte << 8) | lowByte; // Combine high and low bytes to get the distance value in centimeters
      // Store the current distance in the buffer
      distBuffer[bufferIndex] = currentDist;
      bufferIndex = (bufferIndex + 1) % NUM_SAMPLES;
      // Check if all distances in the buffer are decreasing
      bool isDecreasing = true;
      for (int i = 1; i < NUM_SAMPLES; i++) {
        int prevIndex = (bufferIndex + i) % NUM_SAMPLES;
        int currIndex = (bufferIndex + i - 1) % NUM_SAMPLES;
        if (distBuffer[currIndex] >= distBuffer[prevIndex]) {
          isDecreasing = false;
      // Check for significant change
      bool significantChange = (distBuffer[(bufferIndex + 1) % NUM_SAMPLES] - currentDist) > MIN_DISTANCE_CHANGE;
      // Debugging: Print current and average distance
      Serial.print(sensorName);
      Serial.print(" Current Distance: ");
      Serial.print(currentDist);
      Serial.print(" cm");
      // Debugging: Print isDecreasing status
      if (isDecreasing && significantChange) {
        Serial.print(" - Decreasing");
      // If the distance has been decreasing for the last NUM_SAMPLES readings with a significant change
        Serial.println(" Approaching detected");
        return true; // Vehicle is approaching
  return false; // Vehicle is not approaching
Do you have a question ?
yes. My codes are not working correctly. Actually i am making blind corner safety sys using two LiDar sensor facing to each side of road. i want them to detect approaching vehicle only and activate the horn and red light by activating two relays.
We need more details of the problem
What happens when you run the sketch ?
code runs and uploads. but it cant recognizes approaching vehicle and working receding vehicle also.
What do you see if you print the data received from the sensors ? Is it what you expect ?
To determine why not, put in some more Serial.print() statements that test your assumptions.
For example, is this line working as expected? (Hint: probably not).
