Hi all,
I am trying to create a system that has two timers. One is a start delay timer. The second timer is a run-timer.
The start delay timer is able to be set from 15 to 99 minutes via a 20 key matrix keypad. I can enter this value. Although the data is entered in minutes, the subroutine stores this as minutes if the time is less than 60 mins, or as an hour and a number of minutes if the time is over an hour. This bit works well, and gives me a number of flags as well as the time. (code included here, just to give a variable list)
lcd.setCursor (1,2);
do {
char stKey = keypad.getKey();
if (stKey) {
lcd.setCursor ((csr)+1, 2); //move cursor on LCD
lcd.print (stKey); //display character pressed on keypad
if (stKey >= '0' && stKey <= '9') { // only act on numeric keys
startDelay += stKey; // append new character to input string
csr++; //increase cursor count to move on lcd
} else if (stKey == 'E') {
if ((startDelay.length() > 0) && (startDelay.length() <= 2)) {
startDelayMins = startDelay.toInt(); // YOU GOT AN INTEGER NUMBER
if (startDelayMins < 5){
lcd.clear();
lcd.setCursor (3,1);
lcd.print ("Invalid Input");
delay (2000);
lcd.clear();
startDelayFlag = "";
if (startDelayMins > 99){
lcd.clear();
delay (2000);
lcd.clear();
startDelayFlag = 1; // DO YOUR WORK HERE
if (startDelayMins > 60){
delayHrs = 1;
delayMins = (startDelayMins - 60);
Serial.print ("start Delay = ");
Serial.print (delayHrs);
Serial.print (":");
Serial.println (delayMins);
delayFlag = 1;
if (startDelayMins < 60){
delayHrs = 0;
delayMins = startDelayMins;
Serial.print (":");
delayFlag = 1;
startDelay = ""; // clear input
} else if (stKey == 'C') {
startDelayFlag = 2;
lcd.clear();
} while (startDelayFlag !=1);
lcd.clear();
Then there is the run-time setting. This can either be in minutes, if less than 60 minutes: Or it can be in whole hours ( 1-99 hours) again this bit of code works well, but again will be included for completeness. The menu allows flags to be set to indicate whether the number represents minutes or hours.
case 'B':
csr = 0;
runTimeNum = 0;
runTimeFlag = 0;
runTimeHrsFlag = 0;
runTimeMinFlag = 0;
lcd.clear();
lcd.setCursor (3,0);
lcd.print ("Enter Run Time");
lcd.setCursor (2,1);
lcd.print ("Hours OR Minutes");
lcd.print ("Hours");
lcd.setCursor (12,2);
lcd.print ("Minutes");
lcd.setCursor(3,3);
lcd.write (2);
lcd.setCursor (15,3);
lcd.write (3);
char key2 = keypad.getKey();
while(key2 == NO_KEY) key2 = keypad.getKey(); //curly bracket 1
if (key2 == 'U'){
runTimeHrsFlag = 1;
runTimeMinFlag = 0;
if (key2 == 'D'){
runTimeHrsFlag = 0;
runTimeMinFlag = 1;
if ((key2 != 'U') && (key2 != 'D')) {
lcd.clear();
lcd.print ("No Data Input");
delay (2000);
lcd.clear();
lcd.clear();
lcd.clear();
if ((runTimeHrsFlag == 1) && (runTimeMinFlag == 0)){
lcd.setCursor (2,0);
lcd.print("Hours Range 1");
lcd.setCursor (15,0);
lcd.write (1);
lcd.setCursor (16,0);
lcd.print ("99");
if ((runTimeMinFlag == 1) && runTimeHrsFlag == 0){
lcd.print ("Minutes range");
lcd.setCursor (4,1);
lcd.print ("From 15");
lcd.setCursor (11,1);
lcd.write (1);
lcd.setCursor (13,1);
lcd.print ("99");
lcd.setCursor (5,2);
lcd.print ("Enter time");
do {
char rtKey = keypad.getKey();
if (rtKey) {
lcd.setCursor ((csr)+1, 3); //move cursor on LCD
lcd.print (rtKey); //display character pressed on keypad
if (rtKey >= '0' && rtKey <= '9') { // only act on numeric keys
runTime += rtKey; // append new character to input string
} else if (rtKey == 'E') {
if ((runTime.length() > 0) && (runTime.length() <= 2)) {
runTimeNum = runTime.toInt(); // YOU GOT AN INTEGER NUMBER
if ((runTimeNum >=15) && (runTimeNum <= 99) && (runTimeMinFlag ==1)) {
lcd.clear();
runTime = "";
if ((runTimeNum < 15) && (runTimeMinFlag == 1)){
lcd.clear();
delay (2000);
lcd.clear();
runTimeHrsFlag = 0;
runTimeMinFlag = 0;
runTimeFlag = "";
the area I am struggling with is how to set up the two individual timers.
I have a subroutine (void) called runTime. When this is called (all requirements met) I want to run a delay timer. During this timer, I need to monitor an input from a PIR unit, and also output to a sounder device. This gives time to leave the area.
The next timer is a run timer. During this time, I will still need to monitor the PIR and output to the sounder and also output to one other pin.
at the end of the run-time, a simple message ("Process Complete") will be shown on the LCD. again, not a problem. My problem is that I have never used an RTC before. I do not care about days, date, or the current time. everything is relative to the point the 'start button' is pressed.
could someone off any assistance please?
