system
1
is there an easy way to have two loops at the same time???
For Example: i have this code:
char mychar;
int notes[] = {262, 349};
void setup(){
// declare the LED pins as outputs
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
void loop(){
mychar = 'a';
//LED LOOP
if(mychar == 'a'){
digitalWrite(5, LOW);
digitalWrite(6, HIGH);
delay(250);
digitalWrite(5, HIGH);
digitalWrite(6, LOW);
delay(250);}
//Tone Loop
if(mychar == 'a'){
tone(8, notes[0]);
delay(250);
tone(8, notes[1]);
delay(250);
now what i want is that the LED loop and teh Tone loop run at the same time.
and is that easy because im quite a noob at arduino XD
thanks in advance
Robin2
2
You don't need two loops for that. You just need to interleave the actions.
The demo sketch in this Thread illustrates the process. Demonstration code for several things at the same time - Project Guidance - Arduino Forum
You will note that it doesn't use delay() which just paralyzes the Arduino so it can't do anything else.
...R
system
3
Robin2:
The demo sketch in this Thread illustrates the process. http://forum.arduino.cc/index.php?topic=223286.0
...R
Aah, i din't knew it paralized the arduino,.
but i don't quite understand the code.
im just an autistic 14 yo XD
i have alot of programming skills but not with arduino XD
can you please make an example code for me?
if so, thanks alot!
system
4
void loop(){
mychar = 'a';
//LED LOOP
if(mychar == 'a'){
tone(8, notes[0]);
delay(250);
tone(8, notes[1]);
delay(250);}
system
5
yeah, i had that, but it was like an example.
but still thanks XD
system
6
The real trick is to not use "delay()".
Another trick is not to have too many closing braces in your functions.
The compiler doesn't like them.
Robin2
7
jkctech:
The example code is already in the link I gave you.
...R
