Hello,
I have two Mega's. The first with an IR Transmitter Module with DAT plugged into PIN 9.
First Mega Code:
#include <IRremote.h>
IRsend irsend;
irsend.sendRC5(0x0, 8); //send 0x0 code (8 bits)
delay(2000);
irsend.sendRC5(0x1, 8);
delay(2000);
Second Mega has an IR Receiver Module with DAT plugged into PIN 11 and another IR Transmitter Module with DAT plugged into PIN 9.
Second Mega Code:
int IRSend_pin = 9;
int IRRecv_pin = 11; // pin for the IR sensor
int LED = 13; // LED pin
IRrecv irrecv(IRRecv_pin);
decode_results results;
IRsend irsend;
pinMode(IRSend_pin, OUTPUT);
irrecv.enableIRIn(); // Start the receiver
pinMode(LED, OUTPUT);
if (irrecv.decode(&results))
digitalWrite(LED,HIGH);
delay(2000);
delay(100);
digitalWrite(LED,LOW);
irrecv.resume(); // Receive the next value
FYI these are sample codes that I have found on the internet that I tweaked a bit.
The Problem:
I want the first Mega Transmitter to send a signal to the Receiver on the Second Mega. And when that Receiver gets the signal I wan the second Transmitter on the second Mega to send off a signal. It works for two loops and then stops.
If anyone knows what is going on your help would be greatly appreciated.
Thanks you
