This is my first post on this forum, so I will try to be as clear as I can and sorry if I make something wrong.
So I will first explain my situation (my project) and then my problem.
I have two Arduino boards (specifically an Arduino UNO and an Arduino MEGA). The Arduino Uno is connected to my PC where I have a custom program made in Visual Studio and the Arduino Mega is placed on a rover and is reading data from all of its sensors.
The Arduino Mega reads data from the sensors and sends a string with all the data to the Arduino Uno that feeds the string to the PC software trough a serial port. Sometimes the PC software will send a command to the rover, like “ACTIVATE”... . The comma separated string that the Mega send looks something like “Lat, Lng, Battery, Speed”.
Now, sensor readings and motor control is all okay and working. But I can not establish a good bluetooth communication between the two boards. I will explain myself better:
If I attach the Arduino Mega (that’s like if I had attached the Rover directly to my PC) directly to my PC with a USB cable, the board communicates just fine with the software. The PC software reads the string and does all of its calculations and stuff. The problem is that i don’t want to have my rover attached to my PC so my idea is to send this communication string to the Arduino Uno with a HC-12 bluetooth module. The Arduino Uno will receive it and feed that string (without changing anything) to the PC software. I managed to achieve this part.
The problem comes now. I also need to send some commands (not often, only when the user presses some buttons on the PC software) from the PC to the Rover, passing from the UNO. The problem I encounter is that the Mega is constantly sending these update strings to the PC so the UNO can not send something back, and if it somehow manages to send the command, the received command on the Mega is junk. For example if I send a command “ACTIVATE” the Mega will receive “AIVT?” If it even receives something.
Here is where I need help in the code. In the Arduino UNO code I want to be able to recognize when a command in the serial port is being sent from the PC software and immediately stop listening from the incoming strings until the incoming command is sent to the Mega, once that is done the UNO has to restart reading those strings.
On the Mega code I need to receive the full command, elaborate it (I already have the code for the command separation and stuff...) and once the full command is read restart sending those update strings.
It’s like if I had a “normal” operating status that is just the Mega sending strings to the UNO, but If the UNO has a command, this has a higher priority and needs to be sent to the Mega, like a sort of interrupt.
I will attach a “diagram” to try to explain myself a little bit better.
This is the code that I have for the communication. It doesn’t work as intended but I hope to get the idea of what I want to achieve:
On the Arduino UNO
#include <SofwareSerial.h>
SoftwareSerial HC12(10, 11); //I have my module connected to those pins (TX, RX)
void setup(){
HC12.begin(9600);
void loop(){
if(Serial.available()) //That would mean that we have a command incoming from the serial port
HC12.write(Seria.read()); //Write the incoming command to the module
}else //We have not a command incoming
Serial.println(HC12.read()); //Write to the Serial port the incoming string
On the Arduino Mega
String IncomingCommand = “”;
void setup(){
HC12.begin(9600);
void loop(){
if(HC12.available()) //That would mean a command is being received
IncomingCommand = HC12.read(); //Save the incoming command to be processed
}else //No incoming command, send the update string
HC12.println(“String”); //The string is different but just for the test I sent that string
Ps: I know that SoftwareSerial is not that good, I’m using it just for testing. I don’t think that this library is my problem, but if you think let me know.
Thanks to all of those who have read my “poem” and to everyone that wants to help me. If I have made something wrong or if you haven’t understood something please let me know
Thanks,
Stefano
(I am Italian so if I made some mistakes writing please forgive me )
