two xbee simple sketch
hello I am new to arduino
use:
Arduino + 1 + joystick xbee properly configured;
1 arduino with motor shield + one dc motor (forward / reverse) + xbee properly configured.
after several attempts I can not operate the receiver with the char “val” and “j”
////the sketch Arduino without xbee
int JoyStick_X = A0; // x
int j = A0;
int val = A0; // variable to store the value coming from the sensor
int Dir_A = 4;
int Speed_A = 5;
void setup ()
pinMode(Dir_A, OUTPUT);
pinMode(Speed_A, OUTPUT);
Serial.begin (9600); // 9600 bps
// Read location of joystick and calculate the distance and from center
val = analogRead(JoyStick_X); // read the value from the sensor
j = val - 517; // 517 is center positions - how far from center
j = abs(j); //absolute value
// put some bounds on j to keep PWM values useful
// below 100 the motor won’t move and PWM max is 255
if (j >= 510){
j = 510; //the most the PWM pin can do is 255
if (j <=200 && j>=10){
j=200; //below 100 PWM the motor makes a high pich sound and does not move
if (j <=10){
j=0; // below 10 the joystick is very close to center
//Run DC motor A based on analog input from joystick
if (val <= 500) {
digitalWrite(Dir_A, HIGH); // other direction
analogWrite(Speed_A, j/2); // PWM out (divide by 2 because max is 255)
if (val >= 550) {
digitalWrite(Dir_A, LOW); // other direction
if (val <=520 && val >= 510) {
analogWrite(Speed_A, 0); // turn off if the joystick is in the center
// print values for debugging
Serial.print(val); // send numbers to PC so you can see what it going on
Serial.print(",");
Serial.println(j);
TX CODE
int j = A0;
int Dir_A = 4;
int Speed_A = 5;
void setup ()
Serial.print(",");
Serial.println(j);
RX CODE
// Module KY023
// For more info see http://tkkrlab.nl/wiki/Arduino_KY-023_XY-axis_joystick_module
int j;
int val;
int Dir_A = 4;
int Speed_A = 5;
void setup ()
if (Serial.available() <= 550){
val = Serial.read();
j = Serial.read();
if (Serial.available() >= 550) {
j = Serial.read();
if (Serial.available() <=520 && val >= 510) {
j = Serial.read();
Serial.print(",");
Serial.println(j);
So, you have code that looks like crap. EVERY } goes on a line BY ITSELF. Use Tools + Auto Format before posting code, so it doesn’t look like you were drinking heavily while coding. Post code using code tags.
The code does something. You have not explained what it actually does.
You expect the code to do something. You have not explained what you expect it to do.
All that we can surmise is that what the code actually does is not what you expect.
I can assure you that Serial.available() will ALWAYS be less than 520.
I can assure you that Serial.available() will never be greater than (or equal) 550.
mini 4wd with ps2 joystick works with Arduino wire forward / reverse perfectly direction and pwd;
I try to put xbee … (xbee is configured correctly).
excuse for the code is the first post
joystick_easy_mod_rx_mod.ino (1.25 KB)
    if (Serial.available() >= 0)
    j = Serial.read();
It there is one byte available to read, it is NOT OK to read two bytes.
   if (j >= 510){
A byte will never contain a value of 510 or more.
   if (val <= 500) {
You can be certain that that will be true.
if (val >= 550) {
You can be certain that that will be never be true.
ok thanks,,,, I insert the 2 bytes!
I guessed it!
After I post the solution solved
post the solution??
TX CODE
int val = A0; // TX variable to store the value coming from the sensor
int Dir_A = 4; // RX
int Speed_A = 5; //RX
void setup ()
pinMode(Dir_A, OUTPUT); //RX
pinMode(Speed_A, OUTPUT); //RX
Serial.begin (115200); // 9600 bps
if (val <= 510) {
analogWrite(Speed_A,50); // PWM out (divide by 2 because max is 255)
Serial.print(“C”);
if (val >= 530) {
analogWrite(Speed_A,150); // PWM out (divide by 2 because max is 255)
Serial.print(“B”); }
if (val <=530 && val >= 510) {
Serial.print(“G”);
Serial.print("");
RX CODE
#include <SoftwareSerial.h>
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
//tx char
char c = Serial.read();
if (c == ‘C’)
//FORWARD
digitalWrite(13, HIGH);
digitalWrite(12, LOW);
analogWrite(Speed_A, 255); // PWM out (divide by 2 because max is 255)
if (c == ‘B’)
analogWrite(Speed_A, 150); // PWM out (divide by 2 because max is 255)
if (c == ‘G’)
digitalWrite(12, HIGH);
analogWrite(Speed_A, 0); // PWM out (divide by 2 because max is 255)
If you are going to have useless comments, they MUST be correct useless comments.
you like gossip?
