Twos complement?
Hey guys,
I'm still pretty new at this. I'm working on accepting data from a module that sends a number in two bits. I'm told it is positive or negative according to two's complement. While I understand the concept, what do I have to do with the arduino to go from a two-bit two's complement number to an int?
Thanks!
The signed int variables used in Arduino already uses twos complement for negative numbers. To convert a positive number to a negative number in twos complement you invert all the bits and add 1.
I think to convert a 2 bit signed number to a 16 bit signed number you just have to set the extra 14 higher bits to one if the second bit of the smaller number is a one, but not really sure.
Lefty
Gotcha, thanks. I'll give it a go...
Do you mean two parts or two binary bits? Lefty was talking about the latter.
Yes, I did take it as posted literally, as 2 bits, which on the surface is kind of silly I would think, the range would be rather restrictive, no :wink:
Lefty
I'm an idiot, that was a typo. Should have been two BYTES. I assume that changes things?
what do I have to do with the arduino to go from a two-byte two's complement number to an int?
Nothing. On the Arduino a two-byte two's-complement number is an int. Just make certain you get the bytes in the correct order and you're good-to-go.
Cool, so something like this would work?
plMSB = Serial1.read();
plLSB = Serial1.read();
myInt = (int)plMSB<<8;
myInt+= plLSB;
Thanks!
Almost...
You should get in the habit of using a bitwise-or instead of addition when combining bytes...
myInt |= plLSB;
I don't think it's a problem in this case but there are times when using addition leads to a sign extension and that can cause problems.
Perfect, thanks! Still learning :wink:
