spycatcher2k:
Your code does compile, it won’t upload. How are you resetting your mega at upload time?
Indeed. You are right. I forgot to mention an important detail. I need to upload the code with the bluetooth off, by doing this I can ensure that my serial is clear (GND pin is removed). Then when I put it back to turn it on so It can be paired to another device, these errors occurs.
I’m not resetting it. I’m just trying to upload it to the board. And I can’t understand why pins 0 and 1 are not allowing me to do it. Thanks for your interest and feel free to ask.
DrAzzy:
Where’s the code?
Does it have any text strings with three consecutive exclamation points ("!!!") in it?
Many Arduino Mega clones are still sold with an old version of the bootloader with a bug that causes the bootloader to enter a non-functional debugging mode when it encounters a “!!!” in the datastream being sent to it.
No it does not. Here’s the code :
/* Biblioteca padrão do Arduino */
#include <Arduino.h>
#include <string.h>
#include "DefinicoesGlobais.h"
/* Bibliotecas de leitura e escrita para módulo SD */
#include <SD.h>
#include <SPI.h>
/* Bibliotecas de data/hora para módulo DS1307 RTC */
#include <Wire.h>
#include <RTClib.h>
#include <Time.h>
#include <TimeLib.h>
#include <TimeAlarms.h>
/*Biblioteca de Lista Encadeada*/
#include <LinkedList.h>
/* Biblioteca de HashMap */
#include <HashMap.h>
#include "Util.h"
#include "PinChangeInterrupt.h"
/* Biblioteca de Threads */
#include "Thread.h"
#include "ThreadController.h"
#include <Registrador.h>
#include <Mensageiro.h>
#include <Start.h>
#include <Fertilizantes.h>
#include <Eventos.h>
#include <Agendamentos.h>
const byte HASH_SETOR_SIZE = 15;
HashType<int, int> hashRawArray[HASH_SETOR_SIZE];
HashMap<int, int> hashMap = HashMap<int, int>( hashRawArray , HASH_SETOR_SIZE );
//--------- Decladando HashMap de Silos
const byte HASH_SILO_SIZE = 2;
HashType<char*, int> hashSiloArray[HASH_SILO_SIZE];
HashMap<char*, int> hashMapSilo = HashMap<char*, int>( hashSiloArray , HASH_SILO_SIZE);
RTC_DS1307 rtc;
Mensageiro mensageiro;
File arquivo;
File startcfg;
int indiceAgendamento, indiceEvento, indiceFert;
char registrador_nivel;
LinkedList<Agendamentos*> agendamentos = LinkedList<Agendamentos*>();
Agendamentos *chamaFuncao = new Agendamentos();
Start *start = new Start();
int numeroEvento = 0;
int numeroFert = 0;
ThreadController cpu;
Thread thread_teste = Thread();
Thread programacao = Thread();
Thread thread_prepara_irriga = Thread();
Thread thread_prepara_ferti = Thread();
Thread verifica_nivel_tanque = Thread();
Thread recebeVolumeAgua = Thread();
Thread recebeVolumeSilo = Thread();
Thread recupera_silos = Thread();
Thread injecao = Thread();
Thread nivel_injec = Thread();
Thread thread_purga = Thread();
Thread nivel_purga = Thread();
hashMap.debug();
hashMapSilo.debug();
if (!rtc.begin()) {
Registrador::error("Nao foi possivel encontrar modulo RTC");
while (1);
if (! rtc.isrunning()) {
Registrador::info("Inicializando m�dulo RTC!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
char pontoParada;
pinMode(PINO_SD_CS, OUTPUT);
if (!SD.begin(PINO_SD_CS)) {
Serial.println("O cartao falhou ao iniciar ou nao esta presente"); // Trocar "Serial.printl" por "Registrador:error" ap�s os testes.
return;
hashMapSilo[0]("Silo 1", 39);
hashMapSilo[1]("Silo 2", 41);
//---------- Declarando todos os pinos como saidas
pinMode(SETOR_1, OUTPUT);
pinMode(SETOR_2, OUTPUT);
pinMode(SETOR_3, OUTPUT);
pinMode(SETOR_4, OUTPUT);
pinMode(SETOR_5, OUTPUT);
pinMode(SETOR_6, OUTPUT);
pinMode(SETOR_7, OUTPUT);
pinMode(SETOR_8, OUTPUT);
pinMode(SETOR_9, OUTPUT);
pinMode(SETOR_10, OUTPUT);
pinMode(SETOR_11, OUTPUT);
pinMode(SETOR_12, OUTPUT);
pinMode(SETOR_13, OUTPUT);
pinMode(SETOR_14, OUTPUT);
pinMode(SETOR_15, OUTPUT);
pinMode(BOMBA_CAPTACAO_LIGA, OUTPUT);
pinMode(BOMBA_CAPTACAO_DESLIGA, OUTPUT);
pinMode(BOMBA_INJEC_LIGA, OUTPUT);
pinMode(BOMBA_INJEC_DESLIGA, OUTPUT);
pinMode(VALVULA_DESCARTE, OUTPUT);
pinMode(PA_MISTURA_LIGA, OUTPUT);
pinMode(PA_MISTURA_DESLIGA, OUTPUT);
pinMode(SILO_1, OUTPUT);
pinMode(SILO_2, OUTPUT);
pinMode(VALVULA_L2, OUTPUT);
pinMode(CONTRA_LAVAGEM, OUTPUT);
pinMode(BOIA_INFERIOR, INPUT);
pinMode(BOIA_SUPERIOR, INPUT);
// ---------- Declarando o estado inicial de todos os pinos
digitalWrite(SETOR_1, HIGH);
digitalWrite(SETOR_2, HIGH);
digitalWrite(SETOR_3, HIGH);
digitalWrite(SETOR_4, HIGH);
digitalWrite(SETOR_5, HIGH);
digitalWrite(SETOR_6, HIGH);
digitalWrite(SETOR_7, HIGH);
digitalWrite(SETOR_8, HIGH);
digitalWrite(SETOR_9, HIGH);
digitalWrite(SETOR_10, HIGH);
digitalWrite(SETOR_11, HIGH);
digitalWrite(SETOR_12, HIGH);
digitalWrite(SETOR_13, HIGH);
digitalWrite(SETOR_14, HIGH);
digitalWrite(SETOR_15, HIGH);
digitalWrite(BOMBA_CAPTACAO_LIGA, HIGH);
digitalWrite(BOMBA_CAPTACAO_DESLIGA, HIGH);
digitalWrite(BOMBA_INJEC_LIGA, HIGH);
digitalWrite(BOMBA_INJEC_DESLIGA, HIGH);
digitalWrite(VALVULA_DESCARTE, HIGH);
digitalWrite(PA_MISTURA_LIGA, HIGH);
digitalWrite(PA_MISTURA_DESLIGA, HIGH);
digitalWrite(SILO_1, HIGH);
digitalWrite(SILO_2, HIGH);
digitalWrite(VALVULA_L2, HIGH);
digitalWrite(CONTRA_LAVAGEM, HIGH);
digitalWrite(BOIA_INFERIOR, HIGH);
digitalWrite(BOIA_SUPERIOR, HIGH);
programacao.setInterval(1000);
programacao.onRun(Util::verificaProgramacao);
cpu.add(&programacao);
thread_prepara_irriga.enabled = false;
thread_prepara_irriga.setInterval(start->getAtraso());
thread_prepara_irriga.onRun(Util::irriga);
cpu.add(&thread_prepara_irriga);
thread_prepara_ferti.enabled = false;
thread_prepara_ferti.setInterval(300);
thread_prepara_ferti.onRun(Util::fertirriga);
cpu.add(&thread_prepara_ferti);
verifica_nivel_tanque.enabled = false;
verifica_nivel_tanque.setInterval(1000);
verifica_nivel_tanque.onRun(Util::monitoraTanque);
cpu.add(&verifica_nivel_tanque);
recebeVolumeAgua.enabled = false;
recebeVolumeAgua.setInterval(200);
recebeVolumeAgua.onRun(Util::enxeTanque);
cpu.add(&recebeVolumeAgua);
recebeVolumeSilo.enabled = false;
recebeVolumeSilo.setInterval(200);
recebeVolumeSilo.onRun(Util::lancaFert);
cpu.add(&recebeVolumeSilo);
recupera_silos.enabled = false;
recupera_silos.setInterval(2000);
recupera_silos.onRun(Util::despejaFert);
cpu.add(&recupera_silos);
injecao.enabled = false;
injecao.setInterval(start->getPressurizacao());
injecao.onRun(Util::injeta);
cpu.add(&injecao);
nivel_injec.enabled = false;
nivel_injec.setInterval(200);
nivel_injec.onRun(Util::controlaInjec);
cpu.add(&nivel_injec);
thread_purga.enabled = false;
thread_purga.setInterval(500);
thread_purga.onRun(Util::realizaPurga);
cpu.add(&thread_purga);
nivel_purga.enabled = false;
nivel_purga.setInterval(400);
nivel_purga.onRun(Util::controlaPurga);
cpu.add(&nivel_purga);
if (Serial.available() > 0) {
mensageiro.lerSerial();
cpu.run();
