Tx and rx pins
Hey guys, i have a co2 sensor with serial output, can i just plug it into the approprate tx and rx pins on the board to display a readout on the serail monitor?
Not he serial monitor uses those two bits. Use a software serial emulator to read the output from your sensor.
You need to check the signalling very carefully before connecting to your Arduino. If the device uses RS232 voltage levels, it could damage your Arduino.
