TX does not work on Arduino Uno for me
I have connected up an RFID reader to an Arduino . When the RFID reader is activated it sends the data to my arduino which can send it to the serial monitor on my PC via USB. However, I am trying to send the RFID data via the TX pin on my Arduino to a microbit extension.
The TX pin on my Arduino Uno is Connected to an RX pin on an "Octopus:bit" and both grounds are connected. However, the TX pin is not sending the data.
Can someone please help
Code I am using:
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
Serial.println("Approximate your card to the reader...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte < 0x10 ? " 0" : " ");
_ Serial.print(mfrc522.uid.uidByte*, HEX);_
_ content.concat(String(mfrc522.uid.uidByte < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte, HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "51 67 3E 20") //change here the UID of the card/cards that you want to give access*
Serial.println("Book scanned");
delay(3000);
}*_
else {
* Serial.println(" Access denied");*
* delay(3000);*
Which Arduino? How do you know that it does not send?
The serial pins on the Uno also drive the TTL-to-USB converter on the Uno. So whatever you send to the serial monitor will also go to whatever is connected to the TX pin.
If you're using a 32U4 based board, you need to use Serial1.
@UnoCoder
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
