Tx,Rx and ethernet"HELP PLS"
Hey,
pls i need your help guys i have two problems :
1- if any one know how to test ethernet ping,
2 - i have another board that has Rs232 communication so i need to send char caractere in the Rs232 terminal from my arduino mega to the other board ,
For your second problem have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable.
You can send data in a compatible format with code like this
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
...R
ty so much for your reply bro
hope that i will get the answer for the first question from someone else ^^
Hamza1124:
A question would be punctuated with an question mark (interrogative).
