TX/RX pins
Guys, if my TX pin is not blinking (to transmit) when my jumper is at Xbee, what is the problem? :)
I configured my Xbee already but my serial monitor doesn't show anything.
Program is correct, uploading is successful
baudrate?
Baud rate is correct, even if it's wrong, they should show some weird readings on the serial monitor...but there is nothing :'(
TX pins don't blink. TX LEDs blink. If the TX LED is not blinking, it is because nothing is being transmitted.
That the program compiled and uploaded does not make it correct. Post it, so we can see that it is correct.
I'm going to take a stab in the dark, but have you run Serial.begin(baudrate) in setup()?
However, like PaulS said, without the code we can't find what's wrong.
or maybe the wiring. "when my jumper is at..."
