txt to string
 /*I want all the information
     to read sd and drop in
    string and drop in json
    and print json in the serial
    monitor through it.*/
    // But at the output it gives 1-
    //Can you help me? I'm in a hurry
    //I don't know how to put a variable or txt in
//string, and I don't know how to add it to my code. –
        #include <mySD.h>
        File root;
        #include <ArduinoJson.h>
        String b {
          root = SD.open("1.txt");
              if (root) {
              while (root.available()) {
      return (String (root.read()));
          root.close();
        String mydate = b;
        String  json = "{\"sensor\" : \""+mydate+"\"}";
          while (!Serial) continue;
    Serial.print("Initializing SD card...");
  /* initialize SD library with Soft SPI pins, if using Hard SPI replace with this SD.begin()*/
  if (!SD.begin(5)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  /* Begin at the root "/" */
  root = SD.open("/");
  if (root) {
    printDirectory(root, 0);
    root.close();
    Serial.println("error opening test.txt");
          StaticJsonDocument<2000> doc;
          DeserializationError error = deserializeJson(doc, json);
           if (error) {
            Serial.print(F("deserializeJson() failed: "));
            Serial.println(error.c_str());
            return;
          long sensor = doc["sensor"];
          Serial.println(sensor);
    voide loop(){
In that case, no. It won't play out well. Thanks for using code tags though! It would be better if you moved your request text out of the code...
(deleted)
    monitor through it
//string, and I don't know how to add it to my code. -1
#include <mySD.h>
File root;
String b {
if (root) {
root.close();
String mydate = b;
String json = "{"sensor" : ""+mydate+""}";
if (!SD.begin(5)) {
return;
if (root) {
root.close();
if (error) {
return;
voide loop(){
monitor through it
#include <mySD.h>
File root;
String b {
if (root) {
root.close();
String mydate = b;
if (!SD.begin(5)) {
return;
if (root) {
root.close();
if (error) {
return;
voide loop(){
hosein12s:
monitor through it
Sorry, free forums work on their own time...
And you don't know how to properly post your code so people can more easily help you.
I know you are in a hurry, but take the time to read the sticky post at the top of the forum about how to post your code with code tags. It will help people help you.
   monitor through it
   //Can you help me?
      #include <mySD.h>
      File root;
      String b {
            if (root) {
        root.close();
      String mydate = b;
if (!SD.begin(5)) {
  return;
if (root) {
  root.close();
         if (error) {
          return;
  voide loop(){
(deleted)
@hosein12s
you now have a 48 hour ban besides the banning of your sock puppet account.
Take that time to CAREFULLY got through the links below.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Future infraction will result in longer or PERMANENT bans.
