I try to use python to do data logging from an arduino nano. The code works only for several loops, then a error poped up. I am wondering what cause the problem.
The error message:
('5', 1874.8682350429337)
('3', 1167.271553440443)
('3', 1233.2207809135466)
Traceback (most recent call last):
File "/Users/renzha/Library/Application Support/JetBrains/PyCharmCE2021.1/scratches/stream arduino and save files.py", line 262, in <module>
t, V = request_single_voltage (arduino)
TypeError: cannot unpack non-iterable NoneType object
Process finished with exit code 1
python code
while True:
for n in range (0, 11):
names = ['test', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'end' ]
for name in names:
VOLTAGE_REQUEST = 200
arduino = serial.Serial (port, baudrate=115200)
arduino.write (bytes ([VOLTAGE_REQUEST]))
raw = arduino.read_until ()
def parse_raw(raw):
raw = raw.decode ()
if raw [-1] != "\n":
raise ValueError (
"Input must end with newline, otherwise message is incomplete."
if raw [0] == "0":
pass
try:
t, V = raw.rstrip ().split (",")
return int(t), int(V)*5/1023
except ValueError:
pass
def request_single_voltage(arduino):
"""Ask Arduino for a single data point"""
# Ask Arduino for data
# Read in the data
# Parse and return
return parse_raw (raw)
arduino code
const int voltagePin = A0;
//const int HANDSHAKE = 0;
const int VOLTAGE_REQUEST = 200;
int inByte;
unsigned long time_us;
unsigned long currentTime;
unsigned long startTime;
void printVoltage() {
// Delay to get to an even millisecond
delayMicroseconds(1000 - (millis() % 1000));
startTime = millis();
for (int i = 0; i < 8000; i++)
//delayMicroseconds(1000 - (millis() % 1000));
time_us = millis() - startTime;
// Read value from analog pin
int value = analogRead(voltagePin);
// Write the result
Serial.print(time_us);
Serial.print(',');
Serial.println(value);
// Initialize serial communication
// Check if data has been sent to Arduino and respond accordingly
if (Serial.available() > 0) {
// Read in request
inByte = Serial.read();
// If data is requested, fetch it and write it, or handshake
switch (inByte) {
case VOLTAGE_REQUEST:
printVoltage();
//case HANDSHAKE:
//if (Serial.availableForWrite()) {
//Serial.print(""); //Please input:
//break;
