Uno_R4_Space_Invaders.ino (10.0 KB)
* Arduino R4 WiFi Space Invaders
* version 1.0 July, 2023 ++trent m. wyatt
#include <Arduino.h>
#include "Arduino_LED_Matrix.h"
#include <memory.h>
#include <vector>
#include <list>
using std::vector;
using std::list;
#define MAX_Y 8
#define MAX_X 12
#define FIRE_PIN A0
#define LEFT_PIN A1
#define RIGHT_PIN A2
int invader_dir = 1;
uint8_t grid[MAX_Y][MAX_X] = {
{0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
ArduinoLEDMatrix matrix;
void set(int x, int y) {
if (x < 0 || x >= 12 || y < 0 || y >= 8) return;
grid[y][x] = 1;
void reset(int x, int y) {
grid[y][x] = 0;
struct point_t {
int x, y;
point_t() : x(0), y(0) {}
point_t(int _x, int _y) : x(_x), y(_y) {}
typedef char bitmap_t[2][3];
class sprite_t : public point_t {
protected:
bitmap_t sprites[3]; // sprites to sequence through
int num_sprites; // how many sprites we have
int cur; // which sprite is the current displayed sprite
public:
sprite_t()
num_sprites = 0;
cur = 0;
sprite_t(int _x, int _y) : point_t(_x, _y)
num_sprites = 0;
cur = 0;
int width() const {
return 3;
int height() const {
return 2;
void set() const {
for (int row = 0; row < height(); row++) {
for (int col = 0; col < width(); col++) {
if (0 != sprites[cur][row][col]) ::set(col + x,row + y);
void reset() const {
if (0 != sprites[cur][row][col]) ::reset(col+x,row+y);
int get(int const col, int const row) const {
if (col < 0 || col >= width() || row < 0 || row >= height()) return 0;
return sprites[cur][row][col];
void add_sprite(bitmap_t &bm) {
if (num_sprites < int(sizeof(sprites)/(sizeof(*sprites)))) {
memcpy(sprites[num_sprites++], bm, sizeof(bitmap_t));
void next_frame(int const frame = -1) {
if (0 == num_sprites) return;
if (-1 == frame) {
++cur %= num_sprites;
else {
cur = frame % num_sprites;
bool collide(sprite_t &ref) const {
if ((x >= ref.x) && (x < (ref.x+3)) && (y >= ref.y) && (y < ref.y + 2)) {
return true;
return false;
// required to be implemented by all sub-classes:
virtual void init() = 0;
}; // sprite_t
// our base
struct base_t : public sprite_t {
void init() {
bitmap_t data = {
{ 0, 1, 0 },
{ 1, 1, 1 }
add_sprite(data);
base_t() {
init();
base_t(int _x, int _y) : sprite_t(_x, _y) {
init();
}; // base_t
// an invader
struct invader_t : public sprite_t {
void init() {
bitmap_t data1 = {
{ 1, 1, 1 },
{ 1, 0, 0 }
bitmap_t data2 = {
{ 1, 1, 1 },
{ 0, 1, 0 }
bitmap_t data3 = {
{ 1, 1, 1 },
{ 0, 0, 1 }
add_sprite(data1);
add_sprite(data2);
add_sprite(data3);
invader_t() {
init();
invader_t(int _x, int _y) : sprite_t(_x, _y) {
init();
}; // invader_t
// a block
struct block_t : public sprite_t {
void init() {
bitmap_t data = {
{ 1, 1, 1 },
{ 0, 0, 0 }
add_sprite(data);
block_t() {
init();
block_t(int _x, int _y) : sprite_t(_x, _y) {
init();
}; // block_t
// a shot
struct shot_t : public sprite_t {
int dx, dy;
void init() {
bitmap_t data = {
{ 1, 0, 0 },
{ 0, 0, 0 }
add_sprite(data);
dx = 0;
dy = 0;
shot_t() {
init();
shot_t(int _x, int _y) : sprite_t(_x, _y) {
init();
}; // shot_t
vector<invader_t> invaders;
vector<block_t> blocks;
vector<shot_t> shots;
base_t base;
uint32_t last_invader_move = 0;
uint32_t last_shot_move = 0;
uint32_t invader_move_time = 1000;
uint32_t shot_move_time = 75;
void dbg(struct sprite_t &sprite) {
for (int row = 0; row < sprite.height(); row++) {
for (int col = 0; col < sprite.width(); col++) {
Serial.write(sprite.get(col,row) ? "* " : " ");
Serial.write('\n');
void render() {
memset(grid, 0, sizeof(grid));
base.set();
base.next_frame();
for (invader_t &invader : invaders) {
invader.set();
invader.next_frame();
for (block_t &block : blocks) {
block.set();
block.next_frame();
for (shot_t &shot :shots) {
shot.set();
shot.next_frame();
matrix.renderBitmap(grid, MAX_Y, MAX_X);
void move_invaders() {
if (millis() >= last_invader_move + invader_move_time) {
last_invader_move = millis();
int dy = 0;
for (auto &invader : invaders) {
if ((invader.x + invader_dir) < 0 ||
(invader.x + invader_dir) >= (MAX_X - 2))
invader_dir *= -1;
if (1 == invader_dir) {
dy = 1;
invader.x += invader_dir;
invader.y += dy;
if (invader.y >= 4) {
new_game();
else {
if (random(1, 10) > 6) {
shoot(invader.x + 1, invader.y + 2, 0, 1);
void move_shots() {
list<shot_t> next;
if (millis() >= last_shot_move + shot_move_time) {
last_shot_move = millis();
for (auto &shot : shots) {
shot.x += shot.dx;
shot.y += shot.dy;
if (shot.x >= 0 &&
shot.x < MAX_X &&
shot.y >= 0 &&
shot.y <= MAX_Y)
next.push_back(shot);
shots.clear();
for (auto &shot : next) {
shots.push_back(shot);
void shoot(int x, int y, int dx, int dy) {
shot_t shot;
shot.x = x;
shot.y = y;
shot.dx = dx;
shot.dy = dy;
void new_game() {
base.x = 5;
base.y = 6;
invaders.clear();
for (int col = 0; col < 3; col++) {
invader_t invader;
invader.x = col * 4;
invader.y = 0;
invaders.push_back(invader);
blocks.clear();
block_t block;
block.x = col * 4;
block.y = 4;
blocks.push_back(block);
shots.clear();
while (!Serial) { }
Serial.println("Arduino R4 WiFi Space Invaders");
new_game();
Serial.println("invader_t");
dbg(invaders[0]);
Serial.println("block_t");
dbg(blocks[0]);
Serial.println("shot_t");
dbg(shots[0]);
Serial.println("base_t");
dbg(base);
matrix.begin();
pinMode(A0, INPUT);
randomSeed(analogRead(A0));
pinMode(FIRE_PIN, INPUT_PULLUP);
pinMode(LEFT_PIN, INPUT_PULLUP);
pinMode(RIGHT_PIN, INPUT_PULLUP);
render();
void check_block_collisions() {
list<block_t> next_blocks;
vector<shot_t> next_shots;
bool keep = true;
for (shot_t &shot : shots) {
if (shot.collide(block)) {
keep = false;
else {
next_shots.push_back(shot);
if (keep) {
next_blocks.push_back(block);
shots = next_shots;
blocks.clear();
for (auto &block : next_blocks) {
void check_invader_collisions() {
list<invader_t> next_invaders;
bool keep = true;
if (shot.collide(invader)) {
keep = false;
else {
if (keep) {
next_invaders.push_back(invader);
shots = next_shots;
invaders.clear();
for (auto &invader : next_invaders) {
if (invaders.empty()) {
new_game();
void check_base_collisions() {
if (shot.collide(base)) {
for (int i = 0; i < 8; i++) {
base.set();
delay(100);
base.reset();
delay(100);
new_game();
if (!digitalRead(FIRE_PIN)) {
shoot(base.x + 1, base.y, 0, -1);
if (!digitalRead(LEFT_PIN)) {
if (base.x >= 1) { base.x--; }
if (!digitalRead(RIGHT_PIN)) {
if (base.x < (MAX_X - 3)) { base.x++; }
render();
move_invaders();
move_shots();
check_block_collisions();
check_invader_collisions();
check_base_collisions();
delay( 1000.0 / 12.0);
