U64 8x8LED matrix / neo pixels / each 2. show call --> all leds white
Hallo,
have been here for some time now, got a lot of tips from you - great.
Currently I'm using one/two U64 LED 8x8 matrix panels with a D1mini board in a project. I have used it several times with success.
First tests now show strange effects. To find a solution, I went back to the AdaFruit_NeoPixels - simple project for a clean starting point.
Here's the effect:
In general, the panel runs, but every second pixels.show(); call makes the whole panel shine white instead of activating the set LEDs
If I change the well-known simple-loop as follows (show command executed twice), the panel will only light up white for a very short time until the next LED set is set correctly.
  pixels.clear(); // Set all pixel colors to 'off'
  // The first NeoPixel in a strand is #0, second is 1, all the way up
  // to the count of pixels minus one.
  for(int i=0; i<NUMPIXELS; i++) { // For each pixel...
    // pixels.Color() takes RGB values, from 0,0,0 up to 255,255,255
    // Here we're using a moderately bright green color:
    pixels.setPixelColor(i, pixels.Color(0, 150, 0));
    pixels.show();   // Send the updated pixel colors to the hardware.
    delay(DELAYVAL); // Pause before next pass through loop
Any tips what could be the cause?
I have:
  • tested several controllers
  • all libs updated
  • external power supply unit used
  • all soldering points revised
Does anyone know that effect?
Thanks.
Greets
Volker
PS: I know I should do this, but I haven't added the input resistance or the capacitor yet - just for your information.[/code]
interesting side note:
just tested with an LED strip and it worked perfectly
Maybe the matrix is defect?
Thx.
Volker
Fit the resistor and capacitor. If the problem is still present, tell us on this thread.
volkeR1:
Hallo,
Then you know about using code tags.
Done (sorry)
volkeR1:
Done (sorry)
+1 karma
So how about posting all the code?
Why do you need two pixels.show()?
If you want to do 2 of them then try this change
