hi there,i was learn using u8g2 lib,and i search on each website tutorial for ,and my problem happen,when i add font to the logo bitmap where my oled becomes flashing everythime.
this is flshing image problem in my oled:
and this is my code:
#include <U8g2lib.h>
#include <U8x8lib.h>
// This is the display object. You will change this line if you are using pins
// other that 12, 11, 9 and 10.
//U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI display(U8G2_R0, 12, 11, U8X8_PIN_NONE, 9, 10);
//U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE);
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
// This is the battery bitmap
static unsigned char battery_bitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00,
0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00 };
// This is the area inside the battery bitmap, in pixels
#define CHARGE_AREA_START_X 20
#define CHARGE_AREA_START_Y 18
#define CHARGE_AREA_WIDTH 83
#define CHARGE_AREA_HEIGHT 28
// This is the battery fill mode
// BATTERY_MODE_SOLID = 1 means the battery bitmap will be filled with
// a solid rectangle according to the battery charge.
// BATTERY_MODE_SOLID = 0 means the battery will be filled with a
// rectangle subdivided in 3. If the battery level is 66% or more, it will
// draw 3 rectangles. If it's 33% or more, it will draw 2 rectangles. It will
// draw 1 rectagle if the battery is less than 33%.
#define BATTERY_MODE_SOLID 0
// This is the main function, and the one you will want to transplant to your
// code. Pass the battery charge percent and it will draw the battery with
// the corresponding charge level.
void showBatteryLevel(uint8_t percent)
uint8_t width;
if (percent > 100)
percent = 100;
u8g2.clearBuffer();
u8g2.drawXBM(0, 0, 128, 64, battery_bitmap);
if (BATTERY_MODE_SOLID)
width = (percent * CHARGE_AREA_WIDTH) / 100;
u8g2.drawBox(CHARGE_AREA_START_X, CHARGE_AREA_START_Y, width, CHARGE_AREA_HEIGHT);
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
} else if (percent >= 33)
// Show two bars
bars = 2;
} else if (percent > 0)
// Show one bar
bars = 1;
// Show nothing
bars = 0;
uint8_t offset = CHARGE_AREA_START_X;
for (uint8_t i = 0; i < bars; i++)
u8g2.drawBox(offset, CHARGE_AREA_START_Y, 27, CHARGE_AREA_HEIGHT);
offset += 28;
u8g2.sendBuffer();
// Initialize the display object
u8g2.begin();
// A variable to test our code.
unsigned int vbat = 60;
uint8_t percent = vbat;
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_ncenB08_tr); // choose a suitable font
u8g2.drawStr(0,10,"Vbatt:"); // write something to the internal memory
u8g2.sendBuffer(); // transfer internal memory to the display
u8g2.sendBuffer();
// Some test code to scan all the battery levels
showBatteryLevel(percent);
/* write background pattern, then: */
// if (percent <= 33){
// percent--;
// else (percent = 100){
// percent = 100;
delay(50);
how to solve this problem ?
thanks
megantara
