This is a problem that I expected the least, and I refrained as much I could not to bother the professionals here at the forum. But as unforeseen as it may seem, a code that ran well (of course with the help of forum members), compiles well, uploads successfully but does not show anything on the OLED.
The Code below functions to display GPS speed (more details here) and it had been working well on one of the setups. Then I needed to replicate it and odds played against it. I could only get to work the sample codes built into the U8G2 example library. I do not know why something that hasn't altered has refused to function at all!
// PICK ONE of these serial ports:
// BEST: AltSoftSerial on pins 8 & 9 (on an UNO)
//#include <AltSoftSerial.h>
//static AltSoftSerial gpsPort;
static const int RXPin = 4, TXPin = 3;
// 2nd BEST: NeoSWSerial on any two pins
#include <NeoSWSerial.h>
static NeoSWSerial gpsPort(RXPin, TXPin);
static const int GPSBaud = 9600;
// WORST: SoftwareSerial NOT RECOMMENDED
static const bool useOLED = true;
#include <U8g2lib.h>
#define OLED_RESET 5 // Should not be RXPin!
U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2( U8G2_R2, U8X8_PIN_NONE ); // 180 degree rotation
static const int timezonehr = +5; //Timezone hour offset
static const int timezonemn = 30; //Timezone minute offset
#include <NMEAGPS.h>
static NMEAGPS gps;
static gps_fix fix;
static NeoGPS::time_t localTime;
// Display: This section will contain elements for the OLED
static void draw(void) {
// graphic commands to redraw the complete screen should be placed here
//Separator (Vertical Line)
u8g2.drawLine(68,27,68,64);
//GPS:: Checks if GPS has valid fix, then display selective elements
if (fix.valid.location) {
u8g2.drawCircle(122,5,5, U8G2_DRAW_ALL); // GPS fix circle Top Right
u8g2.drawDisc(122,5,3, U8G2_DRAW_ALL);
u8g2.setFont(u8g2_font_7x13_tr);
u8g2.setCursor(72, 9);
u8g2.print( F(" SAT:") );
if (fix.valid.satellites)
u8g2.print( fix.satellites );
if (fix.valid.time) {
// TIME:: Time Elements including conversion of UTC to Local (IST +5.30)
u8g2.setFont(u8g2_font_crox4h_tn); // instead of profont22r?
u8g2.setCursor(0, 14);
if (localTime.hours < 10)
u8g2.print( '0' );
u8g2.print( localTime.hours );
u8g2.print( ':' );
if (localTime.minutes < 10)
u8g2.print( '0' );
u8g2.print( localTime.minutes );
u8g2.print( ' ' );
if (localTime.seconds < 10)
u8g2.print( '0' ); u8g2.print( localTime.seconds );
u8g2.setCursor(44, 11);
if (fix.valid.speed) {
//SPEED:: Displays Speed and other related graphics
float speed = fix.speed_kph();
u8g2.drawFrame(2,59,48,4);
u8g2.drawBox(2,59,(speed/2.5),4);
if ( (int)speed > 100)
u8g2.drawFrame(0,22,64,35);
u8g2.setFont(u8g2_font_logisoso30_tn);
u8g2.setCursor(0, 54);
u8g2.print( (int)speed );
u8g2.setCursor(0, 56);
u8g2.setColorIndex(1);
//u8g2.setFont(u8g_font_orgv01r);
u8g2.setCursor(0, 22);
//u8g2.print("SPEED >>");
//u8g2.setFont(u8g_font_fur30n);
u8g2.setFont(u8g2_font_5x7_mr);
u8g2.setCursor(53, 64);
u8g2.print(F("KM"));
//GPS DATA:: Other GPS related data and statistics
u8g2.setCursor(74, 34); u8g2.print( F("HDOP ") );
if (fix.valid.hdop) u8g2.print(fix.hdop / 1000.0);
u8g2.setCursor(74, 44); u8g2.print( F("ALT ") );
if (fix.valid.altitude) u8g2.print(fix.altitude()); u8g2.print( 'm' );
u8g2.setCursor(74, 54); u8g2.print( F("GPS MODE:") );
if (fix.valid.status) u8g2.print(fix.status);
u8g2.setCursor(74, 64); u8g2.print( F("GPS ERR:") );
if (fix.valid.lat_err) u8g2.print(fix.lat_err());
// lon_err and alt_err also available
gpsPort.begin(GPSBaud);
u8g2.begin();
Serial.println( F("NeoGPS display\n") );
if (gps.available( gpsPort )) {
fix = gps.read(); // get the entire, assembled fix structure
// Shift the date/time to local time
NeoGPS::clock_t localSeconds;
using namespace NeoGPS; // save a little typing below...
localSeconds = (clock_t) fix.dateTime; // convert structure to a second count
localSeconds +=
timezonehr * SECONDS_PER_HOUR +
timezonemn * SECONDS_PER_MINUTE; // shift to desired timezone
localTime = localSeconds; // convert back to a structure
Serial.print( F("ALT=") );
if (fix.valid.altitude) Serial.print(fix.altitude());
Serial.print( F(" PDOP=") );
if (fix.valid.pdop) Serial.print(fix.pdop * 0.001);
Serial.print( F(" HDOP=") );
if (fix.valid.hdop) Serial.print(fix.hdop * 0.001);
Serial.print( F(" VDOP=") );
if (fix.valid.vdop) Serial.print(fix.vdop * 0.001);
Serial.print( F(" SATS=") );
if (fix.valid.satellites) Serial.print(fix.satellites);
Serial.print( F(" GPS Mode=") );
if (fix.valid.status) Serial.print(fix.status);
Serial.print( F(" GPS Data=") );
if (fix.valid.lat_err) Serial.print(fix.lat_err()); // m
Serial.print( F(" TIME=") );
if (fix.valid.time) Serial << localTime;
if (useOLED) {
// Update the display, all at once, during the GPS quiet time
u8g2.firstPage();
do{
draw();
while(u8g2.nextPage());
Please help me rectify the issue as I have no idea what might be outof order in this case.
Thank you for your considerations.
