U8g2 Error:invalid conversion from 'int' to 'const char*' [-fpermissive]
Ho to every one. I succesfull run a simple text in the display, but not show an integer.
/* Read Quadrature Encoder
   Connect Encoder to Pins encoder0PinA, encoder0PinB, and +5V.
   Sketch by max wolf / www.meso.net
   v. 0.1 - very basic functions - mw 20061220
#include <U8g2lib.h>      // make sure to add U8g2 library and restart Arduino IDE
int val;
int encoder0PinA = D2;
int encoder0PinB = D3;
int encoder0Pos = 0;
int encoder0PinALast = LOW;
int n = LOW;
#define OLED_SDA  D2
#define OLED_SCL  D1
#define OLED_RST  D0
U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, OLED_SCL, OLED_SDA , OLED_RST);
const char *text = "U8g2 OTA Demo";  // scroll this text from right to left
  pinMode (encoder0PinA, INPUT);
  pinMode (encoder0PinB, INPUT);
  Serial.begin (9600);
  u8g2.begin();
  u8g2.clearBuffer();          // clear the internal memory
  u8g2.setFont(u8g2_font_8x13B_mf); // choose a suitable font
  u8g2.drawStr(0,10,text);  // write something to the internal memory
  u8g2.sendBuffer();
  n = digitalRead(encoder0PinA);
  if ((encoder0PinALast == LOW) && (n == HIGH)) {
    if (digitalRead(encoder0PinB) == LOW) {
      encoder0Pos--;
      encoder0Pos++;
    Serial.print (encoder0Pos);
    Serial.print ("/");
  encoder0PinALast = n;
  u8g2.clearBuffer();
  //u8g2.drawStr(0,10,"Hola"); //THIS WORK FINE
  u8g2.drawStr(0,10,encoder0PinALast );
  u8g2.sendBuffer();
The error is : invalid conversion from 'int' to 'const char*' [-fpermissive]
if i chhange u8g2.drawStr(0,10,encoder0PinALast ); for u8g2.drawStr(0,10,encoder0PinALast );
Error: request for member 'c_str' in 'encoder0PinALast', which is of non-class type 'int'
I don't know how to solve tis problem :frowning:
If you look at the U8g2lib functions you will see that drawStr() only draws strings. https://github.com/olikraus/u8g2/wiki/u8g2reference#drawstr
If you want to draw a numeric expression you should turn it into a C string first. e.g.
u8
   char buf[7]; //big enough for -32768
   u8g2.drawStr(0,10, itoa(encoder0PinALast, buf, 10) );
This looks a bit messy. So it would be handy to just create a C helper function. Then you can use it in all of your projects.
void drawNumber(int x, int y, int value)
    u8g2.drawStr(x, y, itoa(value, buf, 10);
then you can just say:
Note that this is intended for 16bit integer expressions. You would need a bigger buffer for signed 32bit integers e.g. on Arduino Due.
David.
Edit. Instead of u8g2.drawStr(x, y, "msg") you can use separate
u8g2.setCursor(x, y); and u8g2.print(expression); statements.
Note that this lets you print any kind of expression e.g. float, integer, "msg", String, ...
