u8g2 freezes on Arduino Nano when using PORTC
Hi all!
I started to work on second version of my joystick tester (Bitbucket) a couple of weeks ago, this time with rotary encoder and OLED. After adding a lot of stuff, I managed to use almost all RAM and decided to change my data structures and to use direct port read/write instead of using digitalRead/Write and pinMode. But I hit a show-stopping issue when I tried to use PORTC together with u8g2 library. Here is the minimal code that illustrates the issue:
// 1.3" OLED, connected on A4/A5
#include <U8g2lib.h>
U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
const uint8_t *fontSmall = u8g2_font_profont10_mr; //u8g2_font_profont10_tr;
  // setup OLED
  u8g2.begin();
  u8g2.clearBuffer();
  u8g2.setFont(fontSmall);
  u8g2.setFontRefHeightExtendedText();
  u8g2.setDrawColor(1);
  u8g2.setFontPosTop();
  u8g2.setFontDirection(0);
  // setup pins
  DDRB = 0x10 | 0b00100000; // additional constant for LED
  PORTB = 0x1F;
  DDRC &= 0x11110000;
  DDRC |= 0x04;
  // *** this doesn't work ***
//  PORTC &= 0x11110000;
//  PORTC |= 0x0B;
  // *** this works ***
  digitalWrite(A0, HIGH);
  digitalWrite(A1, HIGH);
  digitalWrite(A2, LOW);
  digitalWrite(A3, HIGH);
  static boolean led = true;
  u8g2.clearBuffer();
  u8g2.setCursor(10,10);
  u8g2.print("PINB:");
  u8g2.print(PINB & 0b11011111, HEX); // exclude LED pin
  u8g2.setCursor(10,20);
  u8g2.print("PINC:");
  u8g2.print(PINC, HEX);
  u8g2.sendBuffer();
  // just to see if loop is running
  if (led) digitalWrite(13,1);
  else digitalWrite(13,0);
  led = !led;
If I use digitalWrite to set A0-A3, everything works as expected. If I use PORTC to set them all at once, the code freezes right after reset of Arduino (LED sometimes flashes 1-2 times, but usually code stops after first run through loop). I do not see what I’m doing wrong with direct port access, it may be something obvious to more experienced Arduino coders.
As I need to be able to change pin meaning on the fly (sometimes 50 times per second), I need to be able to do it after OLED setup (the values in the code are just one of many configurations that I have). I just do not know why digitalWrite access to pins work, while direct manipulation with PORTC doesn’t.
I know that it has something to do with u8g2 library, as when I comment-out u8g2.sendBuffer() call, the LED on Arduino keeps flashing no matter which way I use to set A0-A3.
To answer my own question, I shouldn't program when I'm sleepy... For just that one line, i have put 0x prefix instead of 0b for binary number, I have no idea why. And I do not know why I didn't see such an obvious mistake, of course it didn't work... Sorry for wasting your time.
