Hi Guys,
Anyone up for a challenge?
I have set up a Duinotech 164x64 Display
(Arduino Compatible 128x64 Dot Matrix LCD Display Module | Jaycar Electronics
using the u8g2 library to display a menu from another program (DCSBIOS Library).
The issue is that sometime the menu (void onUfcOptionDisplay1Change) item will be selected and a “:” (void onUfcOptionCueing1Change) will be placed before the menu item.
For example;
abcdefg (not selected)
: abcdefg (selected).
Each of the voids run fine without the other but placing them together (as per below) I get the rest of the screen blanking out when there is a selection.
I understand that this is from the ClearBuffer and nextPage commands.
Yet, I hope someone can think of a workaround to keep the menu item on the screen while the selector changes.
#define DCSBIOS_IRQ_SERIAL
#include "DcsBios.h"
#include "U8glib.h"
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R3, /* clock=*/ 18, /* data=*/ 16, /* CS=*/ 17, /* reset=*/ 13); // Feather HUZZAH ESP8266, E=clock=14, RW=data=13, RS=CS
void onUfcOptionCueing1Change(char* newValue) {
u8g2.setCursor(0,0);
u8g2.setFont(u8g2_font_samim_16_t_all);//u8g2.setFont(u8g_font_5x7);
u8g2.clearBuffer();
u8g2.drawStr(15, 25, newValue);
DcsBios::StringBuffer<1> ufcOptionCueing1Buffer(0x5420, onUfcOptionCueing1Change);
void onUfcOptionDisplay1Change(char*newValue) {
u8g2.setFont(u8g2_font_crox3cb_tr);//u8g2.setFont(u8g_font_5x7);
u8g2.clearBuffer();
u8g2.drawStr(5, 15, newValue);
DcsBios::StringBuffer<4> ufcOptionDisplay1Buffer(0x542a, onUfcOptionDisplay1Change);
u8g2.begin();
u8g2.clear();
DcsBios::setup();
onUfcOptionCueing1Change;
onUfcOptionDisplay1Change;
u8g2.nextPage(); // transfer internal memory to the display
DcsBios::loop();
Thanks in advance for any help/comments.
