HI!
I'm new to arduino (but quick learner) and have problem with my NHD SSD1322 oled screen or with code (using Arduinio nano v3).
Using u8g2 lib.
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
//U8G2_SSD1322_NHD_256X64_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=/ 8); // Enable U8G2_16BIT in u8g2.h
U8G2_SSD1322_NHD_256X64_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 10, / dc=/ 9, / reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
#define image_width 256
#define image_height 64
static const unsigned char image_bits[] PROGMEM = {
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xdf,0xff,0xff,
0xff,0xff,0xff,0xff,0xf9,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xdf,0xff,0xff,0xff,0xff,0xff,0xff,
0xfc,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,0xfe,0xff,
0xff,0xff,0xff,0x7f,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xfc,0xff,0x7f,0xfe,0xff,0x7f,
0xff,0xff,0xfd,0xff,0xdf,0xfe,0xff,0x3f,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfb,0xff,
0xcf,0xfc,0xff,0xbf,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xf7,0xff,0xef,0xf9,0xff,0xcf,
0xff,0xff,0xe7,0xff,0xf7,0xfb,0xff,0xef,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xdf,0xff,
0xf9,0xf7,0xff,0xf3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xdf,0xff,0xfd,0xcf,0xff,0xfb,
0xff,0xff,0xbf,0x7f,0xfe,0x9f,0x7f,0xfc,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x7f,0x3f,
0xff,0x3f,0x3f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xde,0xff,0xff,0x9c,0xff,
0xff,0xff,0xff,0xcc,0xff,0xff,0xc9,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf5,
0xff,0xff,0xe3,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf3,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
#define image2_width 256
#define image2_height 64
static const unsigned char image2_bits[] PROGMEM = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0x1f,0x00,0x00,
0x00,0x00,0x00,0x00,0x06,0xe0,0x01,0x00,0x00,0x00,0x00,0x00,
0x06,0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x06,0x00,
0x00,0x00,0x00,0x00,0x06,0x00,0x06,0x00,0x00,0x00,0x00,0x00,
0x06,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x03,0x00,
0x00,0x00,0x00,0x00,0x06,0xc0,0x01,0x00,0x00,0x00,0x00,0x00,
0x06,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0x0f,0x00,0x00,
0x00,0x00,0x00,0x00,0x86,0xff,0x03,0x00,0x00,0x00,0x00,0x00,
0x06,0x00,0x0c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x18,0x00,
0x00,0x00,0x00,0x00,0x06,0x00,0x18,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x07,0x00,
0x00,0x00,0x00,0x00,0x06,0xe0,0x03,0x00,0x00,0x00,0x00,0x00,
0x06,0x1e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
void setup(void) {
u8g2.begin();
void loop(void) {
u8g2.firstPage();
do {
u8g2.drawXBMP(0,0, image_width, image_height, image_bits);
} while ( u8g2.nextPage() );
delay(1);
u8g2.firstPage();
do {
u8g2.drawXBMP(0,0, image2_width, image2_height, image2_bits);
delay(1);
It's simple code for just showing two looped xbm on screen.
Everything seems to work fine but the screen refresh rate is really slow.(I can actually see those two xbm's moving from up to down)
Is there any way to increase the refresh rate of the screen?
Thanks in advance <3
