Hi Oliver:
I compiled my sketch and it is 32.852 bytes (de un máximo de 32.256 bytes), and I have not finished writing code. I have a Arduino UNO and i have a problem with memory. I use the device DOGM128 of your library:
U8GLIB_DOGM128 scru8g(PIN_D_SCR_SDI, PIN_D_SCR_SCL, PIN_D_SCR_CS, PIN_D_SCR_A0, PIN_D_SCR_RES); //Variable para la pantalla
In the compilation windows i see that there are too many files of devices that i not use in my sketch. For example:
C:\DOCUME~1\AGGUCQ~1\CONFIG~1\Temp\build8223436570558583332.tmp\U8glib\utility\u8g_dev_ssd1306_128x64.c.o C:\DOCUME~1\AGGUCQ~1\CONFIG~1\Temp\build8223436570558583332.tmp\U8glib\utility\u8g_dev_lc7981_160x80.c.o C:\DOCUME~1\AGGUCQ~1\CONFIG~1\Temp\build8223436570558583332.tmp\U8glib\utility\u8g_dev_ssd1325_nhd27oled_gr_new.c.o
etc, etc
How can I do for eliminate those files of compilation?. It's possible?
Thanks again.
