I like the library u8glib but does anyone know if it's possible to created custom fonts? I've looked on the internet and couldn't find a how to guide.
Ok, there is no guide as such, but a description of the converter:
U8glib requires a ".bdf" file for the conversion.
".bdf" can be created from true type fonts with several tools (otf2bdf or fontforge) or you can create a bdf file directly with a font editor, for example fony (fony)
Oliver
Oliver,
Thanks. I'll take a look at that.
Paul
Oliver,
I was able to create the font for u8glib but it just doesn't seem right. I used fony and opened up the font I wanted converted. then I select export to export to a bdf file. Next I used the bdf2u8g software to convert it to a u8glib "c" file. The font I'm converting is Square Sans Serif 7 font. This was the output I got which seems too short.
Fontname:
Copyright:
Capital A Height: 0, '1' Height: 0
Calculated Max Values w= 0 h= 0 x= 0 y= 0 dx= 0 dy= 0 ascent= 0 len= 0
Font Bounding box w= 0 h= 0 x= 0 y= 0
Calculated Min Values x= 0 y= 0 dx= 0 dy= 0
Pure Font ascent = 0 descent= 0
X Font ascent = 0 descent= 0
Max Font ascent = 0 descent= 0
#include "u8g.h"
const u8g_fntpgm_uint8_t SquareSansSerif7[113] U8G_FONT_SECTION("SquareSansSerif7") = {
0,0,0,0,0,0,0,50,0,82,32,127,0,0,0,0,
0,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
255};
I look forward to your response.
Hi
The bdf2u8g version should be this:
https://drive.google.com/folderview?id=0B5b6Dv0wCeCRLWJkYTh2TUlYVDg&usp=sharing
Where are your glyphs in the bdf font? Which commandline options did you use?
Oliver
I too am trying to create a custom font. I have gotten as far as creating the .c font file (see below for the start of it). I am having trouble using it in an .ino that already works with other fonts.
#include "u8g.h"
const u8g_fntpgm_uint8_t u8g_font_bombdrop[1755] U8G_FONT_SECTION("u8g_font_bombdrop") = {
0,6,8,0,255,5,1,9,2,109,32,255,0,8,255,6,...
The first problem is how to reference "u8g.h". I tried relative paths in my .ino, like "clib/u8g.h", but the file is not found (seems that Arduino IDE does not play well with subdirs in such matters). So, I tried copying "clib" as a subdir in my .ino dir, but then the compiler complains that a lot of stuff is doubly defined.
Also, to deal with another compiler complaint I had to add the line...
extern const u8g_fntpgm_uint8_t u8g_font_bombdrop[] U8G_FONT_SECTION("u8g_font_bombdrop");
.... at the top of my .ino file so that I could reference my new font, as in....
u8g.setFont(u8g_font_bombdrop);
So, how best to include "u8g.h" for use in the Arduino IDE with a custom font?
To fill out the picture a bit more, I noticed that u8glib.h includes u8g.h, so I deleted the clib library from my project, added my custom font .c file to the arduino clib subdir (yes, a kludge), added the extern statement to the clib/u8g.h file (an uber kludge) and then referenced my font in the .ino file as I would any other font. This worked, but is really ugly.
I tried to move the custom font stuff to a project library (subdir where my .ino file is). Unfortunately this seems to confuse the Arduino IDE: In the custom font .c file if I include "u8g.h" of <u8g.h> the compiler can't find it. If, instead, I try to include <u8Glib.h>, the compiler finds it but complains about keyword "class" not being found -- seems to get the idea that this is all .cpp. I tried a few combinations of wrapping the custom font stuff in .cpp, .c, and ,h files but that didn't work.
So, can you suggest a better way to incorporate a custom font such that it is outside of the u8glib dirs and files?
I would suggest to just copy the font data into the .ino file itself. Put it somewhere at the top of the .ino file, so that you can refer to the font in the setFont statement. The #include "u8g.h" is not required in this case.
Oliver
Thank's for the library.
I have got it working, but would also like to make a custom font and icons.
I have made a .bdf of my font, and have downloaded the bdf2u8g_101.exe, but I don't understand how I can use the .exe to convert the .bdf file.
I have read this page bdf2u8g · olikraus/u8glib Wiki · GitHub, but I still don't get it.
Can someone please enlighten me.
Cheers, Hal
Hal,
What exactly does not work? Can you generate the .c file file?
Oliver
Hi Oliver
I have the same problem as Hal has!
I've downloaded both "bdf2u8g.exe" and "bdf2u8g_101.exe" bud when I run them on win7 the black cmd window(!) is shown for a while and rapidly disappeares!
Farzad
Farzad,
I guess this should be solved with the latest u8g2 release, right?
Oliver
