Hello,
i´ve got an Oled LCD 128x04 without acknowledge. I´ve downloaded the U8glib.h file and compiled a test program while i´ve updated the hardware list for the arduino (i am working with a stk500 board and avrdude and using the arduino ide in this particulary problem as an ide). While i can compile the test program for atmega cpu´s it will not compile for the attiny85. I have the code:
#include "U8glib.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);
void draw() {
u8g.setFont(u8g_font_unifont);
u8g.drawStr( 0, 20, "Hello World!");
u8g.firstPage();
do {
draw();
} while( u8g.nextPage() );
an the following error with the attiny85 board:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=attiny45 -DF_CPU=20000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/tiny8 /var/folders/32/h3dgvnld4874qs3tvpkm6qv80000gn/T/build8971712682764227742.tmp/sketch_jan03a.cpp -o /var/folders/32/h3dgvnld4874qs3tvpkm6qv80000gn/T/build8971712682764227742.tmp/sketch_jan03a.cpp.o
In file included from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Stream.h:26,
from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/HardwareSerial.h:28,
from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:215,
from sketch_jan03a.ino:3:
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:32:1: warning: "BIN" redefined
In file included from /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/iotn45.h:38,
from /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/io.h:282,
from /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/pgmspace.h:82,
from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:27,
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/avr/iotnx5.h:55:1: warning: this is the location of the previous definition
In file included from sketch_jan03a.ino:3:
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Arduino.h:235:26: error: pins_arduino.h: No such file or directory
sketch_jan03a:3: error: 'U8GLIB_SSD1306_128X64' does not name a type
sketch_jan03a.ino: In function 'void draw()':
sketch_jan03a:7: error: 'u8g' was not declared in this scope
sketch_jan03a:7: error: 'u8g_font_unifont' was not declared in this scope
sketch_jan03a.ino: In function 'void loop()':
sketch_jan03a:16: error: 'u8g' was not declared in this scope
can someone point me in the right direction?
regards
