I have been trying to upload Marlin onto a Ramps 1.4 setup for my DBot printer, using the Marlin file provided in the build guide. I am getting this error
In file included from C:\Users\Eli\AppData\Local\Temp\arduino_build_501193\sketch\dogm_lcd_implementation.h:38:0,
from C:\Users\Eli\AppData\Local\Temp\arduino_build_501193\sketch\ultralcd.cpp:39:
C:\Users\Eli\AppData\Local\Temp\arduino_build_501193\sketch\dogm_font_data_marlin.h:12:25: fatal error: utility/u8g.h: No such file or directory
#include <utility/u8g.h>
compilation terminated.
Using library U8glib_Arduino-master at version 1.19.1 in folder: C:\Users\Eli\Documents\Arduino\libraries\U8glib_Arduino-master
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
when trying to enable the line
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
I have the Library installed correctly because I am able to use it with no problem on a brand new stock sketch of Marlin 1.1.8 as well as on 1.1.6 that I have running on an Anet A8. I am running Arduino 1.8.5 and have recently reinstalled it and all libraries to double check it wasn’t a problem there. I’m pretty stuck on this so any help is very appreciated.
