Hello,
I am working on a project, where I am goint to receive commands via RS-422.
There will be three Arduinos communicating with each other, two UNOs and one MEGA.
At this point I have one Arduino UNO talking to one Arduino MEGA and vice versa.
The Uno "simulates" the RS-422 communication, which is read by the MEGA.
(approx 19200 baud, but there are 21 bits transceived at nonstandart, so I cannot simply use implemented UART for this...)
Then the MEGA collets the data and transformes it into a number, which is stored in a uint32_t variable.
After that the MEGA shall send it back to the UNO via serial UART.
The MEGA talks to the UNO via Serial3.
And now there is my problem. After several successive communications the UNO seems to not receive any commands. For testing I am sanding back "<0xffff>" from MEGA to UNO. After approx 8 times the UNO seems to no longer receive any further commands via UART.
When I reduce the sent message to e.g. "<0xff>", it stops after approx 12 times, and after e.g. "<0xffffffff>" already after approx 4 times. So I think on the side of the UNO there must be some problem in code, like buffer full or sth...
Here Arduino UNO code:
#include <digitalWriteFast.h>
// Write Pin
const uint8_t pin = 2;
uint32_t to_be_sent = 0;
// variables for RS422 send simulation
uint32_t timer_begin = 0;
uint32_t next_slot = 0;
const uint8_t len = 21;
uint32_t buf[len];
// variables for serial simulation
uint32_t receivedNumber = 0;
uint32_t _start = 0;
uint32_t _stop= 0;
pinModeFast(pin, OUTPUT);
to_be_sent = random(0x100000UL,0x200000UL);
transmitRS422 (to_be_sent);
delay(200);
if ( Serial.available() )
processInput();
//delay(1000);
//while(1);
//################### to_be_sent block ####################
void transmitRS422 (uint32_t tbs)
for ( int i = 0; i < len; i++ )
{ // algorithm for shifting number into single bits in buffer buf
buf[i] = tbs & ( 0x100000 >> i );
buf[i] = buf[i] >> ( len - ( i + 1 ) );
} // end for loop
Serial.println(tbs, BIN); // for Debugging
timer_begin = micros(); // store time when first '1' shall be sent
next_slot = timer_begin + 52 ; // store next time slot for next byte (52 us)
while( next_slot > micros() ); // wait for next time slot
digitalWriteFast2( pin, buf[i] ); // write bit
next_slot += 52; // store next time slot for next bit to be sent
} // end for loop
digitalWriteFast2( pin, LOW );
} // end of transmitRS422
//################# end of to_be_sent block #################
//##################### serial block ######################
void processNumber (const long n)
Serial.println("Received via serial:");
Serial.println(n, BIN);
} // end of processNumber
void processInput ()
byte inByte = Serial.read ();
switch (inByte)
case '>':
processNumber (receivedNumber);
case '<':
receivedNumber = 0;
case '0' ... '9':
receivedNumber *= 10;
receivedNumber += inByte - '0';
} // end of switch
} // end of processInput
//################## end of serial block ####################
Here Arduino MEGA code:
// Pins for RS422 communication
const uint8_t PinRead = 2;
const uint8_t PinWrite = 3;
// 21 bits to send (for testing)
uint32_t to_be_sent = 0x12EFE9;
// variables for RS422 receiving
uint32_t buf_Rx[len];
uint32_t ctr_temp = 0;
uint32_t ctr_len = 21;
uint32_t ctr_buf_Rx[len];
uint32_t RS422_TC = 0;
void setup ()
pinModeFast(PinRead, INPUT);
pinModeFast(PinWrite, OUTPUT);
Serial.begin (115200);
Serial3.begin (115200);
} // end of setup
void loop ()
while (digitalReadFast2(PinRead) == LOW);
receiveRS422 (); // call function as soon '1' detected
sendSerial (to_be_sent);
} // end of loop
//################## receiveRS422 block ###################
void receiveRS422 ()
// UFD
// uint32_t vor_schleife = micros();
timer_begin = micros(); // store time when first '1' detected
next_slot = timer_begin + 26; // store next time slot to mid of next byte (26 us)
buf_Rx[i] = digitalReadFast2 ( PinRead ); // read bit
// ctr_buf_Rx[i] = micros (); // UFD
next_slot += 52; // store next time slot for next bit to be read
} // end for loop
RS422_Rx_bits_to_var(buf_Rx);
Serial.println("What is received: ");
Serial.println(RS422_TC, BIN);
// UFD
/* uint32_t nach_schleife = micros();
Serial.print("Verstrichene Zeit fuer gesamten Leseprozess: ");
Serial.print(nach_schleife - vor_schleife);
Serial.println(" us.");
Serial.print("Delay zum Bit-Mittelpunkt nach dem ");
Serial.print(i);
Serial.print(". Durchlauf: ");
Serial.println( ctr_buf_Rx[i] - (timer_begin + 26 + i*52) );
Serial.print("Nach dem ");
Serial.print(i+1);
Serial.print(". Durchlauf: ~");
Serial.print(buf_Rx[i]);
Serial.println("~");
void RS422_Rx_bits_to_var(uint32_t buf_Rx[])
// This function translates received RS422 command bits
// thru DigitalReadFast2() into a uint32_t variable
RS422_TC = 0;
for ( int i = 0; i < 21; i++ )
RS422_TC += ( buf_Rx[i] << ( 20 - i ) );
// UFD
// Serial.print("RS422 TC: ");
// Serial.println(RS422_TC, BIN);
//################ end of receiveRS422 block ################
//################### send serial block ###################
void sendSerial (uint32_t nbr_to_send)
Serial.print ('<'); // send serial-start sign
//Serial3.print (nbr_to_send); // send the number
Serial.print (0xffff); // send the number
Serial.println ('>'); // send serial-stop sign
Serial3.print ('<'); // send serial-start sign
Serial3.print (0xffff); // send the number
Serial3.println ('>'); // send serial-stop sign
} // end of sendSerial
//################# end of send serial block ################
Im happy for any advice! Thank you!
