Uart Class
Hello
I am trying and failing :frowning: to covert a sketch into a libiary.
Using an Arduino Zero.
In sketch form:
Variable of type Uart is defined as follows:
Uart* serPort = &serial2;
There is a function that switches between &serial1 and &serial2.
This works.
Now i am trying to implement the same into the library:
Defined in the main code as follows:
Sender Sender(Serial2);
Here is the header file:
class Sender
public:
Sender(Uart PortIn);
private:
Uart* serPort;
Here is the .cpp file:
Sender::Sender(Uart PortIn)
byte data={0xff,0xaa};
serPort = &PortIn;
serPort->write(data,2);
This complies but somthing must crash on startup as the USB port is lost. Resetbutton has to be presed to start the bootloader.
Please help....
I cannot seem to find what is wrong.
JT
Define the Uart to be always a pointer:
Sender::Sender(Uart *PortIn)
   byte data[]={0xff,0xaa};
   serPort = PortIn;
Make copies of Uart objects isn't a good idea.
Don't forget to use code tags!
