UART communication with CRC
Hello,
After much research on the CRC implementation, I unfortunately failed to implement it. I found a lot of thread on this but can’t code it.
I am new to programming and Arduino. I would be grateful if anyone helps me.
Actually, I want to set up secure UART communication between my PC and Arduino Mega25. I want to send data with CRC code from the serial port of my PC to the Arduino. So for safety after many serach, I decided to use CRC_16_CCITT method.
Here is a simple code for example for the serial implementation. I want to add the CRC calculation to it.
#include <stdio.h>
void setup(){
void loop(){
if (Serial.available() > 0){
char data = Serial.read();
Serial.println(data);
Serial.println(data, BIN);
I found an example (from carnetdumaker.net) like the following code in C, but not sure how can I make a code similar to my arduino code.
[color=#333333][color=#bc7a00]#include[/color] [color=#408080][i]<stdint.h>[/i][/color]
[color=#b00040]uint16_t[/color] [color=#0000ff]crc16_ccitt[/color]([color=#b00040]char[/color][color=#666666]*[/color] data, [color=#b00040]unsigned[/color] [color=#b00040]int[/color] data_len) {
 [color=#b00040]uint16_t[/color] crc [color=#666666]=[/color] [color=#666666]0xFFFF[/color];
 [color=#008000][b]if[/b][/color] (data_len [color=#666666]==[/color] [color=#666666]0[/color])
 [color=#008000][b]return[/b][/color] [color=#666666]0[/color];
 [color=#008000][b]for[/b][/color] ([color=#b00040]unsigned[/color] [color=#b00040]int[/color] i [color=#666666]=[/color] [color=#666666]0[/color]; i [color=#666666]<[/color] data_len; [color=#666666]++[/color]i) {
 [color=#b00040]uint16_t[/color] dbyte [color=#666666]=[/color] data[i];
 crc [color=#666666]^=[/color] dbyte [color=#666666]<<[/color] [color=#666666]8[/color];
 [color=#008000][b]for[/b][/color] ([color=#b00040]unsigned[/color] [color=#b00040]char[/color] j [color=#666666]=[/color] [color=#666666]0[/color]; j [color=#666666]<[/color] [color=#666666]8[/color]; [color=#666666]++[/color]j) {
 [color=#b00040]uint16_t[/color] mix [color=#666666]=[/color] crc [color=#666666]&[/color] [color=#666666]0x8000[/color];
 crc [color=#666666]=[/color] (crc [color=#666666]<<[/color] [color=#666666]1[/color]);
 [color=#008000][b]if[/b][/color] (mix)
 crc [color=#666666]=[/color] crc [color=#666666]^[/color] [color=#666666]0x1021[/color];
 [color=#008000][b]return[/b][/color] crc;
}[/color]
A CRC is used to determine the validity of data, not security. If you want a "secure UART communication" then you would need to apply some form of encryption/decryption to the data passed between the devices.
miilado:
something like this you mean?
(compiles, not tested!)
/*CRC-16 CCITT
    CRC 16 bits
    Polynomial 0x1021
    Initial value 0xFFFF
    No inverted input
    No inverted output
    No final XOR (0x0000)
uint16_t crc16_ccitt(int16_t* data, int16_t data_len) {
  uint16_t crc = 0xFFFF; //initial value
  if (data_len == 0)
    return 0;
  for (unsigned int i = 0; i < data_len; ++i) {
    uint16_t dbyte = data[i];
    crc ^= dbyte << 8;
    for (unsigned char j = 0; j < 8; ++j) {
      uint16_t mix = crc & 0x8000;
      crc = (crc << 1);
      if (mix)
        crc = crc ^ 0x1021; //polynomial
  return crc;
  uint16_t test_data[4] = {1, 2, 3, 4};
  Serial.println("***crc16_ccitt algorithm test***");
  Serial.print("Data set: ");
  for (int i = 0; i < 4; ++i) {
    Serial.print(test_data[i], DEC);
    Serial.print(", ");
  Serial.print("\ncrc16_ccitt: ");
  Serial.print(crc16_ccitt(test_data, 4), DEC);
  Serial.println("");
  if (Serial.available() > 0) {
hope that helps…
markd833:
A CRC is used to determine the validity of data, not security. If you want a “secure UART communication” then you would need to apply some form of encryption/decryption to the data passed between the devices.
Thank you for your explination .
Hmm … so I think the validity would be sufficient in my case! How can I do it?
sherzaad:
if (data_len == 0)
   return 0;
   uint16_t dbyte = data;
   crc ^= dbyte << 8;
     crc = (crc << 1);
     if (mix)
       crc = crc ^ 0x1021;
return crc;
Serial.println(“crc16_ccitt algorithm test”);
 Serial.print(“Data set: “);
   Serial.print(”, “);
 Serial.print(”\ncrc16_ccitt: “);
 Serial.println(””);
hope that helps...
Thank you for your reply.
I have some dobt here:
1- did you use the data that you get from Serial.read() in “crc16_ccitt” function? Because in “void loop()” the datatype of “data” is “char” but the datatype of “data” in “crc16_ccitt” is “int16_t* data” !
2- you calculated the crc but did not use it to transfer with data!
I want to add the “crc” code to the “data” that I get from Serial.read(), then print it out . → (data+crc)
Hope I am clear!
Thank you in advance,
Milad
I’ve implemented UART communication with CRC in SerialTransfer.h. Super easy to use and robust comms library. I chose to use an 8-bit CRC, but you should easily be able to scale the code to 16-bit if you really want to. Here’s the CRC code from my lib:
class PacketCRC
  public: // <<---------------------------------------//public
	uint8_t poly = 0;
	PacketCRC(const uint8_t& polynomial = 0x9B, const uint8_t& crcLen = 8)
		poly      = polynomial;
		crcLen_   = crcLen;
		tableLen_ = pow(2, crcLen);
		csTable   = new uint8_t[tableLen_];
		generateTable();
	void generateTable()
		for (int i = 0; i < tableLen_; ++i)
			int curr = i;
			for (int j = 0; j < 8; ++j)
				if ((curr & 0x80) != 0)
					curr = (curr << 1) ^ (int)poly;
					curr <<= 1;
			csTable[i] = (byte)curr;
	void printTable()
		for (int i = 0; i < tableLen_; i++)
			Serial.print(csTable[i], HEX);
			if ((i + 1) % 16)
				Serial.print(' ');
	uint8_t calculate(const uint8_t& val)
		if (val < tableLen_)
			return csTable[val];
		return 0;
	uint8_t calculate(uint8_t arr[], uint8_t len)
		uint8_t crc = 0;
		for (uint16_t i = 0; i < len; i++)
			crc = csTable[crc ^ arr[i]];
		return crc;
  private: // <<---------------------------------------//private
	uint16_t tableLen_;
	uint8_t  crcLen_;
	uint8_t* csTable;
Power_Broker:
class PacketCRC
uint8_t poly = 0;
	poly      = polynomial;
	crcLen_   = crcLen;
	generateTable();
		int curr = i;
				curr <<= 1;
void printTable()
		if ((i + 1) % 16)
			Serial.print(' ');
	return 0;
	uint8_t crc = 0;
	return crc;
uint16_t tableLen_;
uint8_t  crcLen_;
uint8_t* csTable;
Thank you for your help.
But I could not understand your method :frowning: :frowning: :frowning:
sherzaad:
if (data_len == 0)
   return 0;
   crc ^= dbyte << 8;
     crc = (crc << 1);
     if (mix)
       crc = crc ^ 0x1021;
return crc;
   Serial.print(”, “);
 Serial.println(””);
hope that helps...
Sorry, I understand better now!
Thank you for your help!
But the result that I get is different from the online crc calculator.
CRC-CCITT (0xFFFF)
0x5349
But in my code I get :
crc16_ccitt: 0xE654
What’s your idea, please?
I modified your code a little bit:
uint16_t crc16_ccitt(uint16_t* data, uint16_t data_len) {
  if (data_len == 0)
    return 0;
    uint16_t dbyte = *data;
    crc ^= dbyte << 8;
      crc = (crc << 1);
      if (mix)
        crc = crc ^ 0x1021;
  return crc;
  uint16_t test_data[4] = {1,2,3,4};
  delay(2000);
    Serial.print(", ");
  Serial.print("\ncrc16_ccitt: 0x");
  Serial.print(crc16_ccitt(test_data, 4), HEX);
  Serial.println("");
miilado:
CRC-CCITT (0xFFFF)
0x5349
crc16_ccitt: 0xE654
if (data_len == 0)
   return 0;
   crc ^= dbyte << 8;
     crc = (crc << 1);
     if (mix)
       crc = crc ^ 0x1021;
return crc;
 delay(2000);
   Serial.print(”, “);
 Serial.print(”\ncrc16_ccitt: 0x”);
 Serial.println("");
Kudos for working through the code provided to understand it! 8)
the error in the CRC calculation I believe is because of this line in the routine:
it should be:
hope that helps…
sherzaad:
it should be:
hope that helps....
Thank you, it is because of your support! :blush:
I modified it but it was not the error
I continue to work on the code and hope to find the error ...
miilado:
Not sure what you doing but I check the code with the fix I suggested and it return the expected value.
/*CRC-16 CCITT
    CRC 16 bits
    Polynomial 0x1021
    No inverted input
    No inverted output
  if (data_len == 0)
    return 0;
    crc ^= dbyte << 8;
      crc = (crc << 1);
      if (mix)
        crc = crc ^ 0x1021;
  return crc;
  uint16_t test_data[9] = {0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39};
  for (int i = 0; i < 9; ++i) {
    Serial.print(", ");
  Serial.print(crc16_ccitt(test_data, 9), HEX);
  Serial.println("");
Serial Monitor Output:
Data set: 49, 50, 51, 52, 53, 54, 55, 56, 57,
crc16_ccitt: 0x29B1
CRC calculator check:
sherzaad:
/*CRC-16 CCITT
CRC 16 bits
   Polynomial 0x1021
   No inverted input
   No inverted output
if (data_len == 0)
   return 0;
   crc ^= dbyte << 8;
     crc = (crc << 1);
     if (mix)
       crc = crc ^ 0x1021;
return crc;
Serial.println("crc16_ccitt algorithm test");
   Serial.print(", ");
 Serial.println("");
crc16_ccitt: 0x29B1
![Untitled.png|1366x600](upload://hdft4S6e4QBSEQG0pwPsOs2LKu8.png)
Yes, that's work Thank you ! ???
I have another issue: If I insert data in string like below code, I'll have error? Could you expalin me what will happen? I'm a little bit confused on the datatype configuration!
char test_data = "123456789";
miilado:
correct syntax for a c-string would be:
char test_data[] = "123456789";
to then pass its to the crc routine, it would be:
crc16_ccitt(test_data, strlen(test_data));
hope that helps....
miilado:
Maybe because my method uses a lookup table (much more efficient), but the lookup table is created in a way you should understand if you know how to calculate a CRC value
