UART didn't receiverd
When I tested simulate in Thinkercad, I could see the data in master side, while no data in slave side.
The sketch:
The code in master side:
// C++ code
#define BUTTON 14
char buttonFlag = '0';
char buttonFlagCurre = '0';
  pinMode(BUTTON, INPUT);
  buttonFlag = digitalRead(BUTTON);
  if(buttonFlag != buttonFlagCurre){
    if(digitalRead(BUTTON) == LOW){
      Serial.print('0');
    } else{
      Serial.print('1');
    buttonFlagCurre = buttonFlag;
  } else{
The code in slave side:
// C++ code
#define LED 14
char ledFlag = '0';
  pinMode(LED, OUTPUT);
  while(Serial.available() > 0){
    ledFlag = Serial.read();
  if(ledFlag == '0'){
    digitalWrite(LED, LOW);
  } else{
    digitalWrite(LED, HIGH);
  Serial.print("ledFlag = ");
  Serial.println(ledFlag);
I did not look at the code but you are missing the GND to be shared between the 2 boards
You are right, thanks very much.
have fun !
