Continuing the discussion from Arduino Uno + Grove Wifi V2:
Hi there,
Just a +1 on using the really useful library WiFiEsp. It's very well written, it has lots of debug options and you can learn A LOT if you go through this library's source code too!
I did notice that using SoftwareSerial that rates above 19200 (especially w/o hw flow control) don't really work that well so if you want to use a Grove ESP8266 or something similar controlled by the AT command set from Espressif I recommend that you lower the baud rate like this:
wifiLink.begin(115200);
WiFi.init(&wifiLink);
wifiLink.println("AT+UART_CUR=19200,8,1,0,0");
wifiLink.end();
wifiLink.begin(19200);
You should get an output like so (using the example ScanNetworks sketch included with the library):
[WiFiEsp] Initializing ESP module
[WiFiEsp] >>> TIMEOUT >>>
[WiFiEsp] Initilization successful - 1.1.0
ready
Scanning available networks...
Number of available networks:9
0) BLACKPOOL1 Signal: -77 dBm Encryption: WPA2_PSK
1) BELL292 Signal: -62 dBm Encryption: WPA2_PSK
2) BECKY_INTERNAL Signal: -53 dBm Encryption: WPA2_PSK
3) BLACKPOOL1 Signal: -68 dBm Encryption: WPA2_PSK
4) Francework Signal: -91 dBm Encryption: WPA_WPA2_PSK
5) TheCube2 Signal: -70 dBm Encryption: WPA2_PSK
6) BECKY_INTERNAL Signal: -61 dBm Encryption: WPA2_PSK
7) Hambone Signal: -94 dBm Encryption: WPA2_PSK
8) HP4396B0 Signal: -82 dBm Encryption: None
Cheers! and thank you Bruno (bportaluri in GitHub)!!
Here's the link to the library: GitHub - bportaluri/WiFiEsp: Arduino WiFi library for ESP8266 modules
