UART, Modbus and custom commands
I am more of an ESP and YAML guy these days but I have a requirement to delve back into Arduino for a one-off task and need some help.
I have a solar controller that uses RS485 and a custom modbus. The controller stores settings and real-time data in registers which do not appear to be individually referenceable. The sequence to pull the data is to send a hex-formatted command to the controller and it will send back a hex string with all the contents of the registers.
I have an Arduino Uno hooked up to an C25B RS485 board using pin 0 (RX), pin 1 (TX) and pin 2 as control.
I need a script that will transmit '0x01 0xA3 0x01 0x00 0x00 0x00 0x00 0xA5' and then receive the response from the controller. The string is made up of 'slave address + command type + control code + data1-4 + checksum'. The command type determines which register data is returned.
I've built the same thing in YAML using an ESP32 but the controller is not responding so I want to try a different platform and see if I can get a response.
I'm not entirely sure that modbus actually factors into this and I think that a simple uart.write command should suffice but I'm interested to see how the hive-mind here would approach the challenge. Its been a few years since I wrote code in IDE so I'm definitely rusty.
Hello
Here is an example that should help t1024219.ino - Wokwi Arduino and ESP32 Simulator
It was made to answer this question How to Arduino read the HEXA data stream
Thank you. Reading through both the thread and the code, that seems to be a method to validate the checksum. I have the checksum (it is non-standard or, at least, non-common using Modulo 256). What I need to do is send the hex to the controller and receive the response.
Its also quite possible that I'm missing the key information in the links you posted.
What I think I am looking for is more like this thread but with the ability to send the hex string rather than poll a register.
It seems that as I am using an Uno, I also need to implement SoftwareSerial for the Uno>RS485.
Currently, I have this code that I'm looking to improve although I haven't yet figured out the SoftwareSerial changes that I need to make.
#include <ModbusMaster.h>
#include <SoftwareSerial.h>
#define MAX485_DE     3
#define MAX485_RE_NEG 2
ModbusMaster node;
void preTransmission()
  digitalWrite(MAX485_RE_NEG, 1);
  digitalWrite(MAX485_DE, 1);
void postTransmission()
  digitalWrite(MAX485_RE_NEG, 0);
  digitalWrite(MAX485_DE, 0);
  pinMode(MAX485_RE_NEG, OUTPUT);
  pinMode(MAX485_DE, OUTPUT);
  // Init in receive mode
  // Modbus communication runs at 115200 baud
  //Modbus slave ID 1
  node.begin(1, Serial);
  // Callbacks allow us to configure the RS485 transceiver correctly
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
  byte buf[] = {0x01, 0xA3, 0x01, 0x00, 0x00, 0x00, 0x00, 0xA5};
  Serial.write(buf, 8);
  Serial.write('\n');
  int hexIn = Serial.read();
  delay(30000);
