"uart not available" spam on Serial Monitor
When I upload a sketch to do some debugging, I get "uart not available" spammed for many lines in between valid output. Anyone else experiencing issues with this? I have seen it on multiple devices. Going to check my libraries and see if they have something to do with it, but don't have high hopes.
It happens if an insensible user decides to signal the absents of serial data,
by printing "uart not available".
Serial is very slow.
If seen such insensible code quite often in the context of NRFs,
printing something, if you don't see a packet on each loop turn.
That is why I suspect a library update of some kind- I have not modified the sketch code for a few months, but have just seen this issue within the last couple of weeks.
I have not written any code that prints "uart not available", in case that needed clarifying.
I don't know which code the symptom you describe has, so I have no clue.
Such crude errors are quite rare in libraries, if there are even libraries that have them.
How about a sketch that shows that behavior?
Uploading an unmodified copy of the MKRGSM "TestModem.ino" sketch provides this output:
18:01:31.752 -> Starting modem test...uart not available
18:01:31.752 -> uart not available
18:01:31.797 -> uart not available
18:01:31.843 -> uart not available
18:01:31.936 -> uart not available
18:01:31.982 -> uart not available
18:01:32.074 -> uart not available
18:01:32.120 -> uart not available
18:01:32.120 -> modem.begin() succeeded
18:01:32.120 -> Checking IMEI...uart not available
18:01:32.120 -> Modem's IMEI: ############
18:01:32.120 -> Resetting modem...uart not available
18:01:32.258 -> uart not available
18:01:32.304 -> uart not available
18:01:32.350 -> uart not available
18:01:35.980 -> uart not available
18:01:36.026 -> uart not available
18:01:36.072 -> uart not available
18:01:36.119 -> uart not available
18:01:36.210 -> uart not available
18:01:36.347 -> uart not available
18:01:36.393 -> uart not available
18:01:36.393 -> Modem is functoning properly
What is that and on which platform is it run?
That is the Arduino official MKRGSM library, the sketch is one of the example sketches provided. It runs on the SAMD core platform. I figured this could be assumed considering this is in the MKRGSM1400 hardware category of the forum.
Hmm... just tried a fresh copy of the MKRGSM library v1.5.0, and it goes away... I'll have to look and see what the old copy had in it that may have been causing it.
A good reminder to me: when in doubt, start with fresh copies of the libraries.
Sorry, I didn't notice that.
I have no experience with SAMD uarts, and I don't know that GSM modem.
You could search for the string in the library and have a look,
whether that is a meaningful message, or an error.
From common sense,
that message could be generated when an expected message of the modem does not arrive,
so maybe a misconfiguration that changes the emission of packets,
or a problem of the connection to the modem.
I searched for the string, and sure enough, I found it in the library.
In September I was diagnosing some issues with SMS receiving on MKRNB devices and was comparing the MKRNB library with the MKRGSM one. I must have added the print statement during my testing and forgot to remove it.
This was my mistake and not a library or sketch issue. I appreciate your willingness to chime in, Whandall.
It could have been a message of a legit timeout,
but forgotten debug code is much better than an obscure error. :grinning:
