Hi Folks,
I have been missing data while using Interrupt0 on ATmega328 , what would be the possible remedy to it?
Hi Folks,
@ Nick and rest of the fellowship! this is the code:
#define Relay0 4;
#define Relay1 5;
#define Relay2 6;
#define Relay3 7;
//--Variables--//
String Data;
int AC_LOAD = 3; // Output to Opto Triac pin
int dimming = 128; // Dimming level (0-128) 0 = ON, 128 = OFF
pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output
attachInterrupt(0, zero_crosss_int, RISING); // Choose the zero cross interrupt # from the table above
for (int i=4; i < 8; i++){
pinMode(i, OUTPUT);
digitalWrite(i, LOW);
if(chk == 's'){
Serial.println(Data);
Data = Data.replace('s', ' ');
Data = Data.trim();
char DataChar[4];//char Array to store the char conversion values from DataToInt
Data.toCharArray(DataChar, sizeof(DataChar));
intData = atoi(DataChar);
if (intData == 0) {
digitalWrite(4, HIGH);
Serial.print("here");
if (intData == 1) {
digitalWrite(5, HIGH);
if (intData == 2) {
digitalWrite(6, HIGH);
if (intData == 3) {
digitalWrite(7, HIGH);
if (intData == 5) {
digitalWrite(4, LOW);
if (intData == 6) {
digitalWrite(5, LOW);
if (intData == 7) {
digitalWrite(6, LOW);
if (intData == 8) {
digitalWrite(7, LOW);
void clearing() {
//Serial.print("Clearing ALL");
for(int i=0;i<21;i++)
inData[i]=0;
index=0;
intData = 0;
Serial.flush();
What registers need to be initialised for getting the UART interrupt work:
ISR(USART_RX_vect) {
I couldn't get from the datasheet
EDIT:
Now it compiles fine with the (USART_RXC_vect) ,
@ Sir Nick there was a problem in the code when the ISR is defined as (USART_RX_vect) whereas if its (USART_RXC_vect) then it compiles fine for me? why?
it throws the following error with (USART_RX_vect)
core.a(HardwareSerial.cpp.o): In function
__vector_18': C:\Users\nishant\Downloads\arduino-0022\hardware\arduino\cores\arduino/HardwareSerial.cpp:81: multiple definition of
vector_18'
Bluetooth_Dimmer.cpp.o:C:\Users\nishant\AppData\Local\Temp\build7066994282110513459.tmp/Bluetooth_Dimmer.cpp:40: first defined here
Yes, well HardwareSerial already implements that interrupt so you can't have one as well.
If you miss-spell it, the compiler accepts it, but nothing happens, because there is no such interrupt.
Put it another way, there already is a UART interrupt.
Did you read my message about not using delay?
Sir Nick,
Yes I read your message of not using a delay, I moved that delaying code snippet to another function and perhaps now run it on a Boolean true.
I think I got the problem , even if UART uses interrupts Im not getting the serial.reads fine just because of the priority case as the priority of interrupt0 's priority is very high as compared to the USART_RX_vect priority so it will continue to miss the serial.reads until unless I move that interrupt0 to any other interrupt on other pins so that the serial.reads get priority.
Correct?
#define Relay3 7;
Oh dear!
NI$HANT:
Perhaps if you post your new code. I don't read minds, you know.
NI$HANT:
This is just mumbo-jumbo without seeing your code.
NI$HANT:
Sir Nick
My name is Nick Gammon, you can call me Nick.
Nick, here is the code:
#define Relay0 4;
#define Relay1 5;
#define Relay2 6;
#define Relay3 7;
while(Serial.available() > 0) // Don't read unless
// there you know there is data
inChar = Serial.read(); // Read a character//read the character
if(inChar =='<') //not sure what to put in if statement to run until end
started = true;
ended = false;
index=0;
else if(inChar =='>')
ended = true;
if(started)
inData[index] = inChar; // Store it
index++; // Increment where to write next
inData[index] = '\0'; // Null terminate the string
if (ended)
ended = false;
Data = inData;
clearing();
process();
void process() {
Data = Data.replace('<', ' ');
Data = Data.replace('>', ' ');
Data = Data.trim();
char chk = Data.charAt(0);
if(chk == 'd'){
Data = Data.replace('d', ' ');
Data = Data.trim();
//Serial.println(intData);
dimming = intData;
if(chk == 's'){
Data = Data.trim();
if (intData == 0) {
if (intData == 1) {
if (intData == 2) {
if (intData == 3) {
if (intData == 5) {
if (intData == 6) {
if (intData == 7) {
if (intData == 8) {
void clearing() {
inData[i]=0;
index=0;
intData = 0;
Serial.flush();
I was thinking to implement Pin Change Interrupt Request 2 (pins D0 to D7) (PCINT2_vect) but its priority is also very high as compared to the USART_RX_vect so it will always put my serial.reads back, what to do in such a case?
dimmer == false;
That doesn't do anything useful.
changed it wrongfully wrote that, but what about the priority?
volatile int AC_LOAD = 3; // Output to Opto Triac pin
Why "volatile"? Why not "const"? (and, as a side-order, why not "byte"?)
I will use that variable in interrupt
So? If it never changes it can be const.
I see where you are going with interrupt priority, but the rate of interrupts for 9600 baud is quite slow. I suspect something else is wrong, for example, your debugging prints.
I thought of the same case but even I then I don't think that I will get my Serial.reads read correctly as it will still keep on creating interrupts
Show us your debugging output.
