uart problem can't receive
I am just trying to send a decimal number but I can't receive anything. Here is my code for send on one Arduino:
// Sends "A"s through the serial port every second
// 'Setup' function
  // Start the UART at 9600 bits-per-second (baud)
// Main loop
  // Print an through the UART
  Serial.print(2);
  // Pause 1 second
Here is my receive for the other Arduino:
int incomingByte = 0;      // for incoming serial data
      Serial.begin(9600);      // opens serial port, sets data rate to 9600 bps
      // send data only when you receive data:
      if (Serial.available() > 0) {
            // read the incoming byte:
            incomingByte = Serial.read();
            // say what you got:
            Serial.print("I received: ");
            Serial.println(incomingByte);
Any help is more than welcome!! I know its a simple problem. Oh and I have the tx on one to the rx on the other and vice versa.
Do you have a common "ground" connection ?
yes, i have common ground and vcc.
Maybe try storing the decimal in an integer variable, then sending the variable over serial.
I tried that but I keep getting -1 on the receiving end. I think its that I'm missing the capacitor on pin 3 since I'm using the barebones from modern device and I just built it on a breadboard. I've been connecting the rx after the cap, I'll try before and hopefully that'll fix the problem.
ok I have it working now but when I try sending something I get the same two random variables and then what I sent. Did I burn my arduinos?
Serial.print(2);
2 is the unprintable ASCII control code "STX".
Did you mean Serial.print('2');?
Got it to work. It seems i was type casting it as int instead of char and the single quotes helped too thanks!!
